Iâm having problems while setting up InfluxDB with Grafana.
I have followed every guide I can find. Iâm using Bluetooth 5.0 PCI card and because of this I have to use bluetoothctl instead of hcitool lescan.
When I type âbluetoothctlâ and after that âscan onâ, I do get entries from my tags. I have RuuviCollector up and running and it also says that it does receive data from hcidump.
I cannot see âruuviâ database in InfluxDB when I type âinfluxâ â âshow databasesâ. Also when I start RuuviCollector, I donât see any activity in InfluxDB terminal except those I cause myself with âshow databasesâ. I suspect that my RuuviCollector doesnât want to connect to InfluxDB.
dgerman
December 26, 2020, 9:55pm
2
RuuviCollection talks to syslog configured in /etc/syslog usually going to /var/log/xxx.log
See if there is anything there.
dgerman
December 26, 2020, 10:05pm
3
You should see
DEBUG [Config] Config: /home/pi/RuuviCollector/ruuvi-collector.properties
RuuviCollector[x]:ttt DEBUG [Main] Starting scan with: [hcitool, lescan, --duplicates, --passive]
RuuviCollector[x]: ttt DEBUG [Main] Starting dump with: [hcidump, --raw]
RuuviCollector[x]:ttt INFO [Main] BLE listener started successfully, waiting for dataâŚ
RuuviCollector[x]: If you donât get any data, check that you are able to run âhcitool lescanâ and âhcidump --rawâ without issues
RuuviCollector[x]: ttt INFO [Main] Successfully reading data from hcidump
A sample query for influx command line is
SELECT mac, 32 + last(temperature) * 9 / 5, humidity FROM ruuvi.autogen.ruuvi_measurements GROUP BY mac ORDER BY time ASC TZ(âAmerica/New_Yorkâ)
dgerman
December 26, 2020, 10:06pm
4
You may need to make a dummy script for hcitool because RuuviCollector trys to start that.
How can I make dummy script, Iâm not too familiar with scriptânâstuff, especially with Linux.
dgerman
December 27, 2020, 1:16am
6
Did you find anything in the logs?
I would create a file name hcitool containing
logger --priority daemon.notice. "++ dummy hcitool called with args: $* "
so a message would appear in the /var/log file when it gets run.
You would need to copy it to /usr/bin/hcitool using (note a hash introduces a comment)
sudo mv /usr/bin/hcitool /usr/bin/hcitool.original. # move the original to a safe place
sudo cp hcitool /usr/bin/hcitool # copy the dummy where the original was
sudo chmod a+x /usr/bin/hcitool. # have allusers be able to eXecute it
Then use
sudo systemctl start ruuvicollector.service # restart the ruuvi collector wait 2 minutes then
sudo systemctl status ruuvicollector.service
After I successfully managed to get RuuviCollector service running, this is all it says. Same stuff as it said before running as service (originally it ran in terminal)
This is from syslog
Dec 27 12:01:02 Jarno-Linux systemd[1]: Started Ruuvi Collector service[Service].
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.263 DEBUG [Config] Tag names: /home/eireannanl/Ruuvi/ruuvi-names.properties
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.265 DEBUG [Config] Config: /home/eireannanl/Ruuvi/ruuvi-collector.properties
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.283 DEBUG [Main] Starting scan with: [hcitool, lescan, --duplicates, --passive]
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.284 DEBUG [Main] Starting dump with: [hcidump, --raw]
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.284 INFO [Main] BLE listener started successfully, waiting for data...
Dec 27 12:01:02 Jarno-Linux java[21221]: If you don't get any data, check that you are able to run 'hcitool lescan' and 'hcidump --raw' without issues
Dec 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.668 INFO [Main] Successfully reading data from hcidump
and this is from terminal with status command
ruuvi-collector.service - Ruuvi Collector service[Service]
Loaded: loaded (/etc/systemd/system/ruuvi-collector.service; static; vendor preset: enabled)
Active: active (running) since Sun 2020-12-27 12:01:02 EET; 8min ago
Main PID: 21221 (java)
Tasks: 24 (limit: 18776)
Memory: 55.5M
CGroup: /system.slice/ruuvi-collector.service
ââ21221 /usr/bin/java -jar /home/eireannanl/Ruuvi/ruuvi-collector-0.2.jar
ââ21266 hcidump --raw
joulu 27 12:01:02 Jarno-Linux systemd[1]: ruuvi-collector.service: Succeeded.
joulu 27 12:01:02 Jarno-Linux systemd[1]: Stopped Ruuvi Collector service[Service].
joulu 27 12:01:02 Jarno-Linux systemd[1]: Started Ruuvi Collector service[Service].
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.263 DEBUG [Config] Tag names: /home/eireannanl/Ruuvi/ruuvi-names.properties
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.265 DEBUG [Config] Config: /home/eireannanl/Ruuvi/ruuvi-collector.properties
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.283 DEBUG [Main] Starting scan with: [hcitool, lescan, --duplicates, --passive]
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.284 DEBUG [Main] Starting dump with: [hcidump, --raw]
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.284 INFO [Main] BLE listener started successfully, waiting for data...
joulu 27 12:01:02 Jarno-Linux java[21221]: If you don't get any data, check that you are able to run 'hcitool lescan' and 'hcidump --raw' without issues
joulu 27 12:01:02 Jarno-Linux java[21221]: 2020-12-27 12:01:02.668 INFO [Main] Successfully reading data from hcidump
Anyway, I created that hcitool file (with âtouch hcitool) and copied it to /usr/bin/ (backed up original one). It seems that thereâs no change. Does it matter that files has different icons because of different filetype? âhcitoolâ is plain text documentâ while âhcitool.originalâ is shared library.
Ps. I know that InfluxDB works as I get data from Telegraf (From both local and client)
I tried âstorage.method=dummyâ in âruuvi-collector.propertiesâ but I have no clue where that dummy log would go. At least in â/var/log/â doesnât have any log which would point to that.
dgerman
December 27, 2020, 3:03pm
8
sudo systemctl stop ruuvicollector.service
sudo mv /usr/bin/hcitool /usr/bin/hcitool.dummy # put dummy aside
sudo mv /usr/bin/hcitool.original /usr/bin/hcitool # restore original
What output do you get when running
sudo hcitool lescan --duplicates
While hcitool is running ( or bluetoothctl and scan on) in another terminal window what do you get when running
hcidump --raw
What log messages do you get from system.log about influx?
sudo grep influx system.log|tail -n 20
hcitool isn't available for me as I have bluetooth 5.0 (as far as I know and what my friend told me)
eireannanl@Jarno-Linux:~/Ruuvi$ sudo hcitool lescan --duplicates
Set scan parameters failed: Input/output error
Here's hcidump
eireannanl@Jarno-Linux:~/Ruuvi$ hcidump --raw
HCI sniffer - Bluetooth packet analyzer ver 5.53
device: hci0 snap_len: 1500 filter: 0xffffffffffffffff
< 01 42 20 06 00 00 00 00 00 00
> 04 01 01 00
> 04 0E 04 02 42 20 00
< 01 05 20 06 11 CA 2A 59 59 29
> 04 0E 04 01 05 20 00
< 01 41 20 08 01 00 01 01 24 00 12 00
> 04 0E 04 01 41 20 00
< 01 42 20 06 01 01 00 00 00 00
< 01 01 04 05 33 8B 9E 08 00
> 04 0F 04 00 02 01 04
> 04 3E 2C 0D 01 13 00 01 42 4B 1E 82 6B C4 01 00 FF 7F A2 00
00 00 00 00 00 00 00 00 12 02 01 1E 0A FF 75 00 01 00 02 00
01 03 02 03 19 C0 00
> 04 3E 2D 0D 01 1B 00 01 42 4B 1E 82 6B C4 01 00 FF 7F A3 00
00 00 00 00 00 00 00 00 13 12 09 47 65 61 72 20 53 33 20 28
38 35 32 31 29 20 4C 45
> 04 3E 39 0D 01 10 00 01 37 C7 DD ED D8 32 01 00 FF 7F A8 00
00 00 00 00 00 00 00 00 1F 02 01 1A 03 03 6F FD 17 16 6F FD
63 55 34 C4 F7 9C 0C 90 78 E5 8C 88 AF B7 8E 59 5D 6D 93 3B
> 04 22 0F 01 57 B2 52 B2 1E 00 01 00 00 04 3C B1 19 AB
> 04 3E 34 0D 01 13 00 01 C3 32 7F AF AF 5A 01 00 FF 7F A4 00
00 00 00 00 00 00 00 00 1A 02 01 1A 09 FF C4 00 03 33 02 13
15 80 03 03 B9 FE 08 1B 00 E1 8B B4 BD 3D 20
> 04 3E 33 0D 01 1B 00 01 C3 32 7F AF AF 5A 01 00 FF 7F A2 00
00 00 00 00 00 00 00 00 19 18 09 5B 4C 47 5D 20 77 65 62 4F
53 20 54 56 20 4C 4B 36 31 30 30 50 4C 42
Pretty much nothing else than telegraf related stuff
eireannanl@Jarno-Linux:~/Ruuvi$ sudo grep influx /var/log/syslog|tail -n 20
Dec 27 00:19:43 Jarno-Linux telegraf[9234]: 2020-12-26T22:19:43Z I! Loaded outputs: influxdb
Dec 27 15:19:48 Jarno-Linux telegraf[24017]: 2020-12-27T13:19:48Z I! Loaded outputs: influxdb
Dec 27 15:24:39 Jarno-Linux telegraf[24128]: 2020-12-27T13:24:39Z I! Loaded outputs: influxdb
Dec 27 15:56:41 Jarno-Linux telegraf[24553]: 2020-12-27T13:56:41Z I! Loaded outputs: influxdb
Dec 27 17:09:09 Jarno-Linux telegraf[25377]: 2020-12-27T15:09:09Z I! Loaded outputs: influxdb
Here's what bluetoothctl scan on gives me
[CHG] Device C4:6B:82:1E:4B:42 RSSI: -94
[NEW] Device 79:C5:70:F9:05:11 79-C5-70-F9-05-11
[CHG] Device D1:9D:98:5B:50:DD ManufacturerData Key: 0x0499
[CHG] Device D1:9D:98:5B:50:DD ManufacturerData Value:
05 10 f8 23 06 c4 fe 00 14 ff e8 03 fc b5 36 58 âŚ#âŚ6X
e9 2b d1 9d 98 5b 50 dd .+âŚ[P.
05 10 f8 23 10 c4 ff 00 10 ff e8 03 f0 b5 36 58 âŚ#âŚ6X
e9 36 d1 9d 98 5b 50 dd .6âŚ[P.
05 10 f8 23 0b c5 00 00 14 ff ec 03 f4 b5 36 58 âŚ#âŚ6X
e9 41 d1 9d 98 5b 50 dd .AâŚ[P.
[CHG] Device C3:A8:F4:FC:3A:2F ManufacturerData Key: 0x0499
[CHG] Device C3:A8:F4:FC:3A:2F ManufacturerData Value:
05 fc 12 84 0d c4 cb 00 34 00 14 04 2c 92 b6 55 âŚ4âŚ,âŚU
5e ba c3 a8 f4 fc 3a 2f ^âŚ
[CHG] Device DF:64:E3:55:6A:D3 ManufacturerData Key: 0x0499
[CHG] Device DF:64:E3:55:6A:D3 ManufacturerData Value:
05 10 d0 22 a8 c4 98 ff fc ff d0 03 f4 b8 f6 68 âŚ"âŚh
6e 23 df 64 e3 55 6a d3 n#.d.Uj.
05 10 fa 23 02 c5 02 00 0c ff ec 03 f4 b5 f6 58 âŚ#âŚX
e9 60 d1 9d 98 5b 50 dd .`âŚ[P.
[CHG] Device C3:A8:F4:FC:3A:2F RSSI: -85
05 fc 12 84 16 c4 cc 00 34 00 14 04 28 91 f6 55 âŚ4âŚ(âŚU
5e bf c3 a8 f4 fc 3a 2f ^âŚ
[CHG] Device E3:C9:88:59:4D:8D ManufacturerData Key: 0x0499
[CHG] Device E3:C9:88:59:4D:8D ManufacturerData Value:
05 0f e0 23 29 c4 5d ff e4 ff ec 03 f0 bc b6 9c âŚ#).]âŚ
6e 61 e3 c9 88 59 4d 8d naâŚYM.
I do recognize most mac addresses I see in bluetoothctl scan on
dgerman
December 27, 2020, 4:25pm
10
hcitool error âSet scan parameters failed: Input/output errorâ is somewhat ambiguous. For example it is output if you donât have permissions (forgot sudo) as well as if there is an instance of hcitool already running (like invoked by ruuvicollector)
In any case it seems that you are correct in that the important thing is hcidump is outputting packet dumps.
post output from:
grep --invert-match â^#â ruuvi-collector.properties | grep --invert-match â^.$â
dgerman
December 27, 2020, 4:37pm
11
also
systemctl status influxd
influx
show databases #not including ruuvi is bad
Here's terminal output for greps
[quote=âdgerman, post:10, topic:4569, full:trueâ]
post output from:
[/quote]
eireannanl@Jarno-Linux:~/Desktop$ grep --invert-match '^#' /home/eireannanl/Ruuvi/ruuvi-collector.properties|grep --invert-match '^.$'
influxUrl=http://jarno-linux.localhost:8086/
influxDatabase=ruuvi
influxMeasurement=ruuvi_measurements
filter.mode=none
storage.values=extended
influxdb.service - InfluxDB is an open-source, distributed, time series databa>
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor prese>
Active: active (running) since Sun 2020-12-27 18:44:46 EET; 11min ago
Docs: https://docs.influxdata.com/influxdb/
Main PID: 5885 (influxd)
Tasks: 15 (limit: 18776)
Memory: 29.4M
CGroup: /system.slice/influxdb.service
ââ5885 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
joulu 27 18:54:51 Jarno-Linux influxd[5885]: [httpd] fe80::cb8:fef5:276:4de7%wlp>
joulu 27 18:54:52 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
joulu 27 18:54:55 Jarno-Linux influxd[5885]: [httpd] fe80::cb8:fef5:276:4de7%wlp>
joulu 27 18:55:02 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
joulu 27 18:55:12 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
joulu 27 18:55:20 Jarno-Linux influxd[5885]: [httpd] fe80::cb8:fef5:276:4de7%wlp>
joulu 27 18:55:22 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
joulu 27 18:55:25 Jarno-Linux influxd[5885]: [httpd] fe80::cb8:fef5:276:4de7%wlp>
joulu 27 18:55:32 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
joulu 27 18:55:43 Jarno-Linux influxd[5885]: [httpd] 127.0.0.1 - - [27/Dec/2020:>
Database has ruuvi as I have created it with âcreate database ruuviâ. As far as I know (which is very little), it doesnât have any effect whether it is there or not.
show databases
eireannanl@Jarno-Linux:~$ influx
Connected to http://localhost:8086 version 1.8.3
InfluxDB shell version: 1.8.3
> show databases
name
telegraf
_internal
ruuvi
dgerman
December 27, 2020, 9:48pm
13
Restore (or comment out
Logs the measurements to the log rather than sending them anywhere, feasible for testing and development
Increase the width (number of columns) for your terminal and issue
systemctl status influxd --lines=50 --no-pager
systemctl IMHO is rude and stops outputting at the edge of the terminal window!
we are looking for many
Dec 27 16:43:22 pi93graf influxd[4866]: [httpd] 127.0.0.1 - ruuvi [27/Dec/2020:16:43:20 -0500] âPOST /write?db=ruuvi&rp=autogen&precision=n&consistency=one HTTP/1.1â 204 0 â-â âokhttp/3.11.0â 897bf962-488c-11eb-b7c8-b827eb1c5b93 2490110
At least up through the okhttp/3.11.0
Here's InfluxDB stuff you requested
[quote=âdgerman, post:13, topic:4569â]
eireannanl@Jarno-Linux:~$ systemctl status influxd --lines=50 --no-pager -l
â influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2020-12-28 05:25:15 EET; 5min ago
Main PID: 1052 (influxd)
Tasks: 14 (limit: 18776)
Memory: 133.0M
ââ1052 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
joulu 28 05:28:43 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:28:43 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" c949fee4-48bc-11eb-8043-f07959609fdf 34472
joulu 28 05:28:53 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:28:53 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" cf2318ae-48bc-11eb-8044-f07959609fdf 236363
joulu 28 05:28:53 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:28:53 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" cf3fed90-48bc-11eb-8045-f07959609fdf 272263
joulu 28 05:29:03 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:03 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" d535ce04-48bc-11eb-8046-f07959609fdf 480759
joulu 28 05:29:12 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:29:11 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "-" da61955b-48bc-11eb-8047-f07959609fdf 47598
joulu 28 05:29:13 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:13 +0200] "GET /ping HTTP/1.1" 204 0 "-" "InfluxDBShell/1.8.3" db06b775-48bc-11eb-8048-f07959609fdf 42
joulu 28 05:29:13 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:13 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" db2bbb98-48bc-11eb-8049-f07959609fdf 47338
joulu 28 05:29:16 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:16.364916Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SHOW DATABASES"
joulu 28 05:29:16 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:16 +0200] "POST /query?chunked=true&db=&epoch=ns&q=show+databases HTTP/1.1" 200 123 "-" "InfluxDBShell/1.8.3" dcfe71f5-48bc-11eb-804a-f07959609fdf 723
joulu 28 05:29:19 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:19.765402Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SHOW DATABASES"
joulu 28 05:29:19 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:19 +0200] "POST /query?db=&epoch=ns&q=SHOW+DATABASES HTTP/1.1" 200 123 "-" "InfluxDBShell/1.8.3" df055349-48bc-11eb-804b-f07959609fdf 666
joulu 28 05:29:23 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:23 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" e121a49d-48bc-11eb-804c-f07959609fdf 354327
joulu 28 05:29:23 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:23.728791Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SHOW MEASUREMENTS ON ruuvi"
joulu 28 05:29:23 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:23 +0200] "POST /query?chunked=true&db=ruuvi&epoch=ns&q=show+measurements HTTP/1.1" 200 57 "-" "InfluxDBShell/1.8.3" e1621699-48bc-11eb-804d-f07959609fdf 516
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.543656Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT usage_user, usage_system FROM telegraf.autogen.\"Server CPU\" WHERE (cpu = 'cpu-total') AND time >= now() - 12h"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.545106Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'Memory') AND time >= now() - 12h GROUP BY time(1m), hardware fill(linear)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.546488Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(used) / (1024 * 1024 * 1024), mean(free) / (1024 * 1024 * 1024) FROM telegraf.autogen.\"Server Memory\" WHERE (host = 'Jarno-Linux') AND time >= now() - 12h GROUP BY time(1m)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.547003Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'GPU Memory') AND time >= now() - 12h GROUP BY time(1m), hardware fill(linear)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27Memory%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29%2C+%22hardware%22+fill%28linear%29%3BSELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27GPU+Memory%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29%2C+%22hardware%22+fill%28linear%29 HTTP/1.1" 200 11891 "-" "Grafana/7.3.6" e1de91eb-48bc-11eb-804f-f07959609fdf 9540
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.554588Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'CPU Total') AND time >= now() - 12h GROUP BY time(1m) fill(none)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.555549Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (hardware = 'NVIDIA GeForce GTX 970') AND time >= now() - 12h GROUP BY time(1m) fill(none)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22used%22%29++%2F+%281024%2A1024%2A1024%29%2C+mean%28%22free%22%29++%2F+%281024%2A1024%2A1024%29+FROM+%22Server+Memory%22+WHERE+%28%22host%22+%3D+%27Jarno-Linux%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28null%29 HTTP/1.1" 200 12255 "-" "Grafana/7.3.6" e1ded8f0-48bc-11eb-8050-f07959609fdf 10102
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27CPU+Total%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28none%29%3BSELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22hardware%22+%3D+%27NVIDIA+GeForce+GTX+970%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28none%29 HTTP/1.1" 200 4571 "-" "Grafana/7.3.6" e1e0169a-48bc-11eb-8051-f07959609fdf 4554
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.562516Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'CPU Total') AND time >= now() - 12h GROUP BY time(1m)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.563534Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (hardware = 'NVIDIA GeForce GTX 970') AND time >= now() - 12h GROUP BY time(1m)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+%22usage_user%22%2C+%22usage_system%22+FROM+%22Server+CPU%22+WHERE+%28%22cpu%22+%3D+%27cpu-total%27%29+AND+time+%3E%3D+now%28%29+-+12h HTTP/1.1" 200 47293 "-" "Grafana/7.3.6" e1de5f0c-48bc-11eb-804e-f07959609fdf 22895
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27CPU+Total%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28null%29%3BSELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22hardware%22+%3D+%27NVIDIA+GeForce+GTX+970%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28null%29 HTTP/1.1" 200 6171 "-" "Grafana/7.3.6" e1e1500b-48bc-11eb-8052-f07959609fdf 5901
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.569872Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'GPU Memory') AND time >= now() - 12h GROUP BY time(1m), hardware fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.571193Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Load WHERE (sensor = 'Memory') AND time >= now() - 12h GROUP BY time(1m), hardware fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27GPU+Memory%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29%2C+%22hardware%22+fill%280%29%3BSELECT+mean%28%22value%22%29+FROM+%22Load%22+WHERE+%28%22sensor%22+%3D+%27Memory%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29%2C+%22hardware%22+fill%280%29 HTTP/1.1" 200 5801 "-" "Grafana/7.3.6" e1e26dc3-48bc-11eb-8053-f07959609fdf 4570
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.588507Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Temperature WHERE (hardware = 'AMD Ryzen 5 5600X' AND sensor = 'Core (Tctl/Tdie)') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.590386Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Temperature WHERE (hardware = 'NVIDIA GeForce GTX 970' AND sensor = 'GPU Core') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Temperature%22+WHERE+%28%22hardware%22+%3D+%27AMD+Ryzen+5+5600X%27+AND+%22sensor%22+%3D+%27Core+%28Tctl%2FTdie%29%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29%3BSELECT+mean%28%22value%22%29+FROM+%22Temperature%22+WHERE+%28%22hardware%22+%3D+%27NVIDIA+GeForce+GTX+970%27+AND+%22sensor%22+%3D+%27GPU+Core%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29 HTTP/1.1" 200 3917 "-" "Grafana/7.3.6" e1e5433d-48bc-11eb-8054-f07959609fdf 7009
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.698069Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Power WHERE (hardware = 'AMD Ryzen 5 5600X' AND sensor = 'Package Power') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.699236Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Throughput WHERE (sensor = 'Upload Speed' AND hardware = 'Ethernet') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.702383Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Power WHERE (hardware = 'NVIDIA GeForce GTX 970' AND sensor = 'GPU Package') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.702852Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(value) FROM telegraf.autogen.Throughput WHERE (sensor = 'Download Speed' AND hardware = 'Ethernet') AND time >= now() - 12h GROUP BY time(1m) fill(0)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Power%22+WHERE+%28%22hardware%22+%3D+%27AMD+Ryzen+5+5600X%27+AND+%22sensor%22+%3D+%27Package+Power%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29%3BSELECT+mean%28%22value%22%29+FROM+%22Power%22+WHERE+%28%22hardware%22+%3D+%27NVIDIA+GeForce+GTX+970%27+AND+%22sensor%22+%3D+%27GPU+Package%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29 HTTP/1.1" 200 5369 "-" "Grafana/7.3.6" e1f5eefd-48bc-11eb-8056-f07959609fdf 10345
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22value%22%29+FROM+%22Throughput%22+WHERE+%28%22sensor%22+%3D+%27Upload+Speed%27+AND+%22hardware%22+%3D+%27Ethernet%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29%3BSELECT+mean%28%22value%22%29+FROM+%22Throughput%22+WHERE+%28%22sensor%22+%3D+%27Download+Speed%27+AND+%22hardware%22+%3D+%27Ethernet%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%280%29 HTTP/1.1" 200 6178 "-" "Grafana/7.3.6" e1f5eeaa-48bc-11eb-8055-f07959609fdf 10670
joulu 28 05:29:24 Jarno-Linux influxd[1052]: ts=2020-12-28T03:29:24.729413Z lvl=info msg="Executing query" log_id=0RLquNXW000 service=query query="SELECT mean(used) / (1024 * 1024 * 1024) FROM telegraf.autogen.\"Server Disk\" WHERE (device = 'sda5') AND time >= now() - 12h GROUP BY time(1m) fill(linear)"
joulu 28 05:29:24 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0, fe80::cb8:fef5:276:4de7%wlp5s0,127.0.0.1 - admin [28/Dec/2020:05:29:24 +0200] "GET /query?db=telegraf&epoch=ms&q=SELECT+mean%28%22used%22%29++%2F+%281024%2A1024%2A1024%29+FROM+%22Server+Disk%22+WHERE+%28%22device%22+%3D+%27sda5%27%29+AND+time+%3E%3D+now%28%29+-+12h+GROUP+BY+time%281m%29+fill%28linear%29 HTTP/1.1" 200 6849 "-" "Grafana/7.3.6" e1fac44e-48bc-11eb-8057-f07959609fdf 7964
joulu 28 05:29:33 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:29:33 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" e6f2338c-48bc-11eb-8058-f07959609fdf 36033
joulu 28 05:29:33 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:33 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" e7178cf1-48bc-11eb-8059-f07959609fdf 41118
joulu 28 05:29:41 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:29:41 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "-" ec10251a-48bc-11eb-805a-f07959609fdf 46448
joulu 28 05:29:43 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:43 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" ed0d752e-48bc-11eb-805b-f07959609fdf 43952
joulu 28 05:29:54 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:29:53 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" f2e76fc4-48bc-11eb-805c-f07959609fdf 901086
joulu 28 05:29:54 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:29:53 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" f30359b5-48bc-11eb-805d-f07959609fdf 751316
joulu 28 05:30:03 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:30:03 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" f8f93e7b-48bc-11eb-805e-f07959609fdf 37905
joulu 28 05:30:11 Jarno-Linux influxd[1052]: [httpd] fe80::cb8:fef5:276:4de7%wlp5s0 - - [28/Dec/2020:05:30:11 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "-" fded8ac1-48bc-11eb-805f-f07959609fdf 39138
joulu 28 05:30:13 Jarno-Linux influxd[1052]: [httpd] 127.0.0.1 - - [28/Dec/2020:05:30:13 +0200] "POST /write?db=telegraf HTTP/1.1" 204 0 "-" "Telegraf/1.17.0 Go/1.15.5" feef1d45-48bc-11eb-8060-f07959609fdf 33749
dgerman:
I had dummy on as I was testing if I would see some log where ruuvi-collector would write those but couldnât find one.
Oh, and bluez didnât like me, gave me bluetooth failed to set mode failed (0x03) in logs and org.bluez.error.notready when I tried to use bluetoothctl scan on
otso
December 28, 2020, 8:52am
15
RuuviCollector uses HCIDump internally, so your case might need some reworking of the program to support bluetoothctl.
Iâm not sure what the data on your hcidump is, but itâs not from RuuviTags.
Where else could that data come from since those Mac addresses are my tagsâ addresses.
D1:9D:98:5B:50:DD is tagâs address which Iâm currently holding. I have 6 tags total.
Reworking sounds like awfully many hours googling stuff . Especially when Iâm doing that.
otso
December 28, 2020, 11:28am
17
bluetoothctl scan is from RuuviTags,
dgerman:
hcidump --raw
is something else.
RuuviCollector/src/main/java/fi/tkgwf/ruuvi/Main.java at 3970d5b8520f6e4005d4f23e0c8d225ff886a255 ¡ Scrin/RuuviCollector ¡ GitHub looks like the place that would need to be reworked to support bluetoothctl, or possibly the run() could pick the correct implementation somehow.
@scrin FYI
I see. Well, Iâm able to do something with my Linux day after tomorrow so if Iâm lucky, Scrin might have solution by then.
I havenât compared bluetoothctl scan and hcidump --raw but Iâm sure you know what you are talking about.
dgerman
December 28, 2020, 3:07pm
19
As Otso said, the hcidump you posted does not include any packets
that have Ruuvi ID xâ0499â which appear as 99 at the end of the hcidump line and the 04 is on the next line.
Example
hcidump --raw |grep --after-context=2 âFF 99 $â
04 3E 2B 02 01 03 01 1A 1E 4A 74 FA F7 1F 02 01 06 1B FF 99
04 05 11 94 34 CD C5 4C 00 0C FF DC 04 00 97 F6 9C 39 77 F7
FA 74 4A 1E 1A B9
â
04 3E 2B 02 01 00 01 0F EC 72 78 51 D3 1F 02 01 04 1B FF 99
04 05 0A CE 65 02 C5 21 00 D4 00 0C 03 CC A2 F6 00 BF C4 D3
51 78 72 EC 0F 9E
Which explains why you do not see any log entries from
which include
âŚruuvi [27/Dec/2020:16:43:20 -0500] âPOST /write?db=ruuviâŚ
Scrin
December 29, 2020, 6:07pm
20
Thereâs actually a way to set the âscan commandâ in the configuration , which by default is hcitool lescan --duplicates --passive. This would need to be changed to the bluetoothctl equivalent to start the BT LE scanning (as the broadcast packets from RuuviTags are not visible in BT Classic scanning ). Iâm not too familiar with bluetoothctl (yet) so Iâm not sure on this one.
Any mechanism that starts the process of receiving the LE packets from the (physical) bluetooth controller to the OS is sufficient, as RuuviCollector grabs the raw packets from the bluez stack using hcidump. This can even be some crazy script that does some very low level poking to the controller directly, or any command of more âhigh levelâ tools to get the same result.
