What size SD card do you plan to use?
I think I go with 16Gb card. Sure 8Gb would be enough I think, but at local stores seemed that there was only “brand” Silicon Power card at 8Gb. That sure would be cheap (2€) but better choose something with good quality. What card would you suggest?
btw. what method do you suggest to write ready configured system from card to image, in case I sometime end up trying that also?
SD card performance (in my experience with Pi Zero) is important.
More than you wanted to know!
https://en.wikipedia.org/wiki/SD_card#Speed
More analysis than you want to know
https://elinux.org/RPi_SD_cards and http://www.pidramble.com/wiki/benchmarks/microsd-cards
Too many choices. I go with a well known memory manufacture like Kingston, PNY SanDIsk and check the analysis.
Write the card with https://www.balena.io/etcher/ it is easy (takes gz) safe(finds SD card) and free
Image of running RuuviCollector on a Raspberry Pi Zero W, with grafana for a 16GB SD and IMPORTANT notes at http://MyBeacons.info/RuuviCollectorSD.html . Let me know if it works for you (or if it doesn’t)
Thanks, just downloading image. I bought Sandisk Ultra SDHC as originally planned and seems like that’s sold also with officially preflashed rasbian. My Zero W is on it’s way but seems it wil take longer for it until arrives. Will test and report when posible to do so.
Thanks again.
Yeah certainly could be used as a BLE to wifi gateway and looks fine.
Please post you experience here.
Just to say I have developed a Pi Zero WH based IOT cellular gateway for BLE devices plus other Smart Device protocols too - works great .
