Any questions about the Eddystone firmware? Shoot!
But please read the documentation first.
Thanks for creating this product.
My first impression with ruuvitag+ was wonderful. My observations:
Kindly find screenshots for the reference.
rgds,
Vivek Agarwal
Welcome and thanks for your feedback!
Thanks Lauri. Now I was able to change firmware & was able to broadcast different url. But when I tried to broadcast amazon.in url; beacon became untraceable.
Glad to hear it works!
Note that the Physical Web requires HTTPS.
Weather station URL is traceable on iPhone but as soon as I am uploading another firmware Chrome widget is not detecting physical web on iPhoneâs today view. However, url from another firmware is traceable on Androidâs nearby.
Could you describe the problem in more detail?
Probably there is something wrong with the URL that prevents iOS Chrome giving notifications.
FYI, a great video about Nearby.
URL address is http://www.papertreasure.in which is redirecting to https://www.facebook.com/papertreasure. Androidâs Nearby is detecting the physical web but iPhoneâs chrome widget is not detecting the same.
Seems that the URL is not using HTTPS. Fix it and try again.
nRF Connect is working well on my Android phone but doesnât show the URL on iPhone. It seems that app is looking different on iPhone.
Power optimization of Eddystone example is now complete, and the update package can be found at https://ruu.vi/setup/packages/20170118-eddystone.zip.
On default settings the passcode is 00112233445566778899aabbccddeeff. Nordic smartphone app ânRF Beacon for Eddystoneâ accepts the pass code as-is, web configuration tool expects prefix â0xâ to signal that passcode is a hex number while Nordic app does not accept the prefix. Updating the firmware does not reset the password or settings if you have already configured something else.
On default setting of broadcasting URL https://ruu.vi/setup at 1 Hz @ 0 dBm the average current consumption is ~10 ”A (measured with Nordic Power Profiler Kit). A CR2450 battery with 600 mAh of capacity (similar to ones shipped in KS campaign devices) should last teoretically for ~60 000 hours or ~6 years +, practical lifetime will be less due to battery aging and characteristics degrading over use.
Hi guys,
i have a short question:
Where / How do i get the Eddystone notifications on my iOS device?
Android is working fine!
regards
Cloud
Did you try these instructions:
https://google.github.io/physical-web/try-physical-web
Recently i came over this but i was irritated. The Chrome widget is not installed on iOS deviced by default, is it?
That means that every iOS user needs to install this chrome widget and then activate Nearby Notifications in it? I donât think that a high percentage use / know this or am I wrong?
But please donât misunderstand me. I know that this is not the ruuvitags fault.
Regards
Luke
Yes, itâs not installed by default and need to be installed. I believe when user benefits from beacons is increasing also Apple will add native support for Eddystone. Hopefully quite soon.
if Eddystone is compatible to Appleâs iBeacon, shoudnât the broadcast been shown on Apple devices natively?
Both Eddystone and iBeacon are protocols. Itâs compatible with Iphone when you install Chrome and enable Physical web feature. But it still needs Chrome app installed to iPhone.
thanks. but isnât iBeacon natively built into iOS?
Hello, my ruuvitag+ arrived some days ago
It came with the weather station firmware which worked really well and as expected. The reason I bought the device though was to use as a beacon to trace a lost model plane or drone. I have flashed the Beacon firmware and using nRF beacon for Eddystone I can unlock and configure the beacon and have ânearbyâ working but then I get lost into how I then use this to track a lost model. It looks like I need to use spontaneous geocaching as in the find treasure example. Has anyone got a basic guide as to how I can use my ruuvitag as a proximity locator beacon.
many thanks, jamie
Update: after a little research came across Beacon Scanner which gives a range and an active signal chart of any beacons in range. Because models fly normally in open space I should hopefully get a reasonable range. A better solution would also log gps, maybe an option for ruuvitag ver2
What prog do I need to open and change the weather station zip file?
