I’m bit confused, is there custom Node-RED node for RuuviTag available?
EDIT: Here is link for that: https://github.com/ojousima/node-red
Great node! Working like a charm
and I finally replace my crontab task for monitoring every 10min my RuuviTag+s placed in every room of my house
If someone is interested, here is my flow. Enjoy!
"id": "4a8bdd14.b8273c",
"type": "inject",
"z": "a0d43e19.34e2",
"name": "Start BLE scan every 10min",
"topic": "startBLEScan",
"payload": "{ \"scan\": true }",
"payloadType": "json",
"repeat": "600",
"crontab": "",
"once": true,
"x": 210,
"y": 80,
"wires": [
"e57b915d.d96dc"
"id": "e57b915d.d96dc",
"type": "scan ble",
"uuids": "",
"duplicates": false,
"name": "",
"x": 590,
"y": 120,
"wires": [
"8065e07d.317b18"
"id": "8065e07d.317b18",
"type": "ruuvitag",
"name": "",
"x": 760,
"y": 120,
"wires": [
"28a3f1f8.c6ddb6"
"id": "6fb8c7d6.e16b18",
"type": "inject",
"name": "Stop BLE scan every 10min",
"topic": "stopBLEScan",
"payload": "{ \"scan\": false }",
"repeat": "600",
"crontab": "",
"once": true,
"x": 200,
"y": 160,
"wires": [
"f9c4ebfe.f3f47"
"id": "3057eda0.382f72",
"type": "debug",
"name": "",
"active": true,
"console": "false",
"complete": "true",
"x": 1150,
"y": 60,
"wires": []
"id": "f9c4ebfe.f3f47",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "10",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 410,
"y": 160,
"wires": [
"e57b915d.d96dc"
"id": "28a3f1f8.c6ddb6",
"type": "function",
"name": "Generate MQTT topic",
"func": "var device = null;\n if (msg.peripheralUuid == \"aaaaaaaaaaaa\") {\n device = \"bedroom1\";\n} else if (msg.peripheralUuid == \"bbbbbbbbbbbb\") { \n device = \"livingroom\";\n} else if (msg.peripheralUuid == \"cccccccccccc\") { \n device = \"kitchen\";\n} else if (msg.peripheralUuid == \"dddddddddddd\") { \n device = \"bathroom\";\n} else if (msg.peripheralUuid == \"eeeeeeeeeeee\") { \n device = \"bedroom2\";\n} else if (msg.peripheralUuid == \"ffffffffffff\") {\n device = \"bedroom3\";\n}\nmsg.topic = device + \"/measurements\";\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 960,
"y": 120,
"wires": [
"e35e99c4.f1c26",
"3057eda0.382f72"
"id": "e35e99c4.f1c26",
"type": "mqtt out",
"name": "",
"topic": "",
"qos": "",
"retain": "",
"broker": "ec06f45c.253818",
"x": 1150,
"y": 120,
"wires": []
"id": "ec06f45c.253818",
"type": "mqtt-broker",
"z": "",
"broker": "localhost",
"port": "1883",
"clientid": "",
"usetls": false,
"compatmode": false,
"keepalive": "60",
"cleansession": true,
"willTopic": "",
"willQos": "0",
"willPayload": "",
"birthTopic": "",
"birthQos": "0",
"birthPayload": ""
@etatto Great stuff. Thanks for sharing this!
Somehow I don’t manage to get the ruuvitag node visible. I can see it as installed form manage packages, but there’s only a greyed out box and it’s not available in the palette on the left side. Any suggestions on how to proceed?
This was related to “use strict” missing in the js file, which caused my node version to bail out.
hi,
i cant get it worked and i got this error. any advise ?
[scan ble:62ac8d50.337474] Unable to start BLE scan. Adapter state: unauthorized
thanks
Would you share how you parse the information from Node-Red in OpenHAB? By a rule?
you need to set some caps for the nodejs executable like this:
setcap cap_net_raw+eip $(eval readlink -f $(which node))
There is nothing to decode: the payload contains all the measurements
I’m adding a “topic” property to the “msg” object and sending it to my mqtt broker.
Hope it helps…
The question was intact, how to get the data from the MQTT Topic til OpenHAB. Do you parse the string eg. like:
outdoor/measurements {“humidity”:72.5,“temperature”:-0.33,“pressure”:102729,“accelerationX”:16,“accelerationY”:-20,“accelerationZ”:1052,“battery”:3091}
in a OpenHAB rule?
sorry I didn’t read it closely…
so one item file per ruuvitag:
// /etc/openhab2/items/rhus6.items
String rhus6Measurements "Mesures" { mqtt = "<[mqtt:rhus6/measurements:state:default]" }
DateTime rhus6LastUpdate "Dernière lecture [%1$td/%1$tm/%1$tY %1$tR]" <calendar>
Number rhus6Battery "Batterie [%.2f V]"
Number rhus6BatteryIcon "IcĂ´ne 'Batterie'"
Number rhus6Humidity "Humidité [%.2f %%]" <humidity>
Number rhus6Pressure "Pression atmosphérique [%.2f hPa]" <pressure>
Number rhus6Temperature "Temperature [%.2f °C]" <temperature>
and one rules file per ruuvitag:
// /etc/openhab2/rules/rhus6.rules
rule "rhus6Update"
when
Item rhus6Measurements received update
then
rhus6LastUpdate.postUpdate(new DateTimeType())
var String json = (rhus6Measurements.state as StringType).toString
var Double battery = new Double(transform("JSONPATH", "$.battery", json)) / 1000
var Double humidity = new Double(transform("JSONPATH", "$.humidity", json))
var Double pressure = new Double(transform("JSONPATH", "$.pressure", json)) / 100
var Double temperature = new Double(transform("JSONPATH", "$.temperature", json))
rhus6Battery.postUpdate(battery)
if ( battery < 2.50) {
rhus6BatteryIcon.postUpdate(0)
if (battery >= 2.50 && battery < 2.55) {
rhus6BatteryIcon.postUpdate(10)
if (battery >= 2.55 && battery < 2.60) {
rhus6BatteryIcon.postUpdate(20)
if (battery >= 2.60 && battery < 2.65) {
rhus6BatteryIcon.postUpdate(30)
if (battery >= 2.65 && battery < 2.70) {
rhus6BatteryIcon.postUpdate(40)
if (battery >= 2.70 && battery < 2.75) {
rhus6BatteryIcon.postUpdate(50)
if (battery >= 2.75 && battery < 2.80) {
rhus6BatteryIcon.postUpdate(60)
if (battery >= 2.80 && battery < 2.85) {
rhus6BatteryIcon.postUpdate(70)
if (battery >= 2.85 && battery < 2.90) {
rhus6BatteryIcon.postUpdate(80)
if (battery >= 2.90 && battery < 2.95) {
rhus6BatteryIcon.postUpdate(90)
if (battery >= 2.95 ) {
rhus6BatteryIcon.postUpdate(100)
rhus6Humidity.postUpdate(humidity)
rhus6Pressure.postUpdate(pressure)
rhus6Temperature.postUpdate(temperature)
end
and you need the JSONPath Transformation Add-on for the rules
That was exatcly the missing part - thanks a lot.
You are welcome
After long long time I started from scratch and installed Node.js & Node-RED to my C.H.I.P. (Note I’m completely newbie at this, so look at least summary at the end
Basicly the Idea came from here:
Well I have managed to set Ruuvi-node and InfluxDB to Node-RED, as noble with npm install node-red-contrib-noble. I have given that command which should allow to use BLE when not root. Well there’s still problem cause I don’t see any BT related at Node-RED like there’s at yours workflow pics.
My goal atm. is just to able to read data from RuuviTag to database, later I probably try to get those information to Thingboard, if this is usable:
https://techink.site/node-red-thingsboard/
Just makes me wonder if at the end I choose not to use grafana at all (I might but not sure), would it be better to use some different database, at least at thingsboard page there is:
“ThingsBoard is able to use SQL or NoSQL(Cassandra) database layer. By default, ThingsBoard uses embedded HSQLDB instance which is very convenient for evaluation or development purposes.”
That’s for installed version as said in here:
But if thing different if using IoT PaaS Demo?
Hope you can give me some pointers which would lead me to right direction. One thing I did notice when writing this and checking things I’ve made was that npm installation of noble said that first should be installed following package: libbluetooth-dev
Comparing that to this: https://github.com/sandeepmistry/noble#running-without-rootsudo
This says: bluetooth bluez libbluetooth-dev libudev-dev some of those weren’t installed but are installed now.
So the summary :
@otso I have installed that ojousima node-red ( RuuviTag node) and I’m able to use it in Node-RED, but that easy part (installing noble with npm install node-red-contrib-noble) does add it in node_modules folder, but at Node-RED UI there’s nothing bluetooth related nodes.
So what am I doing wrong here?
