Hey everyone,
I have started exploring Ruuvi Tags and their applications & I am impressed with their potential for IoT projects. I want to set up a temperature and humidity monitoring system for my indoor plants and want advice.
What is the best way to configure the Ruuvi Tag for this use case? Are there any apps or integrations you suggest that work well with the tags for real time monitoring? I have seen mentions of using third party platforms for data visualization any favorites?
Also I have check this article and resorse https://f.ruuvi.com/t/ruuvitag-in-my-lab-best-platform-for-setting-up-monitoringrpa-dev witch is good for those who have used Ruuvi Tags in similar setups, do you have tips on placement or settings to get the most accurate readings?
Thank you ![]()
