However, I note that the way that was implemented was to modify the task_acceleration_fifo_full_task function, which was called every time the FIFO was called.
But looking through the repository history I see that said function was removed, and I haven’t been able to ascertain if it was refactored to another area of the code base, or removed completely, or indeed how you go about reading the accelerometer FIFO when it is full.
So how do I go about replicating that functionality from the original article, but with the current firmware as the base?
In short, you’ll want to enable GPIO interrupt on nRF52, enable FIFO, enable FIFO GPIO interrupt on LIS2DH12. Once FIFO interrupt fires, read and process data.
To stop working with FIFO data, disable interrupt on LIS2DH12, disable FIFO and disable FIFO GPIO interrupt on nRF52 .
Relevant functions in commit are app_sensor_fifo_collection_start, app_sensor_fifo_collection_stop and on_accelerometer_fifo_isr
