I am looking for ways to secure Ruuvitag to a person’s wrist for persistent monitoring of his body movement. Found wearable mount online 3D design Ruuvi RuuviTag Mount | Tinkercad by Malesmave. Anyone has something similar to share?
I also want to use ML to identify body movement vs static position (e.g to alert if the person is to remove Ruvvitag from his wrist). Or can we leverage on the onboard NFC in any way for this purpose?
Hello, I once wrapped a RuuviTag in a sock and tied the sock on my wrist. That one on Tinkercad looks a lot better
NFC probably can’t be used, as the NFC read range is really low. You might have some luck with the temperature, wrist is probably warmer than air but I’ve not tried it.
RuuviTag cannot act as a NFC reader, only as a NFC tag. Also having the NFC reader in the strap would lead to a high power consumption, as NFC reads are pretty power intensive.
