We are looking for a developer to set up a RuuviTag + Raspberry Pi 4 gateway for use with a new application for environmental monitoring. Applications include cigar humidor sensor, wine humidor sensor, greenhouse sensor.
There are some examples that almost do what you want if you google (e.g. https://blog.ruuvi.com/rpi-gateway-6e4a5b676510) that might work as a staring point for a non developer. If you are going to make a product you might consider ESP32 as gateway plattform instead of Raspberry Pi to lover the cost.
Regards,
Marcus
You can use my demo project RuuviTag Demo as a starting point:
Hi @TBSD
You can try https://github.com/balda/ruuvitag-discovery with Home Assistant, which can be easily installed on a Raspberry Pi, both configurable with a UI (no code
See https://www.home-assistant.io/getting-started/ then https://github.com/balda/ruuvitag-discovery/blob/master/DOCS.md
