The user should be able to specify which data items to chart on a per sensor basis.
Examples
“backdoor” : temp,humidity and movements.
“freezer” : temp,humidity and movements.
“outside cellar door” : temp, movements and Z-axis.
“dehumidifier” : humidity, temperature, movements.
“raccoon trap” : z-axis, movements, temperature.
“sump pump” : movements, z-axis, humidity
“garage door” : z-axis, movements, temperature.
“boat”: z-axis, movements, temperature.
“attic fan”, movements, temperature, battery-voltage.
“clothes dryer”, movements, humidity, temperature.
“clothes washer”, movements, humidity, temperature
See mybeacons.info for use case examples.
I really don’t appreciate what the current air pressure tells me.
All the pieces of code are presently available. Of course nothing is as easy it first appears.
