How can I monitor log message output from the ruuvitag application running on the ruuvitag? I am using the Ruuvi arduino connector with a NRF52DK. Before plugging in the ruuvitag arduino connector with ruuvitag attached I can download example apps to the NRF52DK and monitor the log using the JLINK usb serial port. When I plugin the ruuvitag arduino adapter I can build and download ruuvitag applications but I still only get the debug log messages from the app running on the NRF52DK.
I assume you’re writing your own firmware? Please check that NRF_LOG_ENABLED is set to 1 and NRF_LOG_BACKEND is RTT.
Do I need to copy a sdk_config.h from one of the nRF52DK examples? In the ruuvitag_fw examples, there is no sdk_config.h as there is in all of the nRF52DK SDK examples. I used the ruuvitag_fw current git repository to build the bootloader/ruuvitag_b_debug/armgcc and the unmodified ruuvitag_firmware example. I also made sure the bootloader sdk_config.h has the NRF_LOG_ENABLED set to 1 and NRF_LOG_BACKEND RTT. I put all the hex output including the s132_nrf52_3.0.0_softdevice.hex soft device in the packet.hex and used the usb JLINK drive to transfer the packet.hex to the ruuvitag mounted on the nRF52DK ruuvi arduino connector. The ruuvitag_firmware app is working correctly as the LEDs work as they should and I am able to access the sensor via a python web script or the android ruuvitag app. The only serial debug output I am getting on the linux /dev/ttyACM0 serial port is from the nRF52DK
ble_app_blinky example which I build using the nRF5_SDK_15.0.0_a53641a which is running on the nRF832 processor on the nRF52DK.
I’d recommend you to use SD 3.1.0, available from Nordic Semiconductor.
You need to use JLinkRTTViewer or SES debug window to view the logs.
NRF_LOG_xxx are macros and are compile time enabled.
consider adding these defines to your main.c
#define NRF_LOG_ENABLED 1 // requires ruuvi dev kit(including Nordic kit) to see log messages
#define NRF_LOG_DEFAULT_LEVEL 4 // 4 debug: see everything via jlink & /usr/local/bin/JLinkRTTClient or telnet localhost 19021
#define NRF_LOG_USES_COLORS 1
#define NRF_LOG_ERROR_COLOR 2 // RED
#define NRF_LOG_WARNING_COLOR 5 // BLUE
Thank you. This looks like what I am looking for. First pass I don’t see anything from JLinkRTTClient. Maybe I need to also configure bootloader sdk_config.h. For now I have been able to monitor the RTT debug output and debug the ruuvitag app using the Segger embedded studio.
I have found getting JLinkRTTClient started unpredictable.
Once it gets going it’s great.
If you don’t see output from it, other than dots, try killing it and starting it again.
I have not modified Bootloader.sdk_config.h and I can see all expected LOG messages (once it gets going) even ones that occurred earlier and have been queued!
Depending on your development environment, you might need to start JLinkExe and connect to the target board as the JLinkRTTClient will connect on JLinkExe on Mac OSX and Linux. I think Windows doesn’t need starting up JLinkExe separately, but I’m not 100% sure.
otso, I am now running JLinkExe and when I attempt to connect I get the following. I am new to nRF52 DK/SDK so I am not sure what works using the nRF52DK without a JTAG which I don’t have. I am using JLink usb through the nRF52DK usb connection:
J-Link>connect
Device “NRF52832_XXAA” selected.
Connecting to target via JTAG
TotalIRLen = ?, IRPrint = 0x…000000000000000000000000
Cannot connect to target.
J-Link>
When I connect to the target ruuvitag mounted on the nRF52DK using the ruuvi arduino adapter using usb 0 I get:
J-Link>usb 0
Disconnecting from J-Link…O.K.
Connecting to J-Link via USB…O.K.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 12 2018 11:44:41
Hardware version: V1.00
S/N: 682620304
VTref=3.300V
J-Link>
Try the SWD:
J-Link>SWDSelect
Select SWD by sending SWD switching sequence.
****** Error: Debugger tries to select target interface SWD.
This interface is not supported by the connected emulator.
Selection will be ignored by the DLL.
****** Error: Could not transfer JTAG data.
****** Error: Not supported by current CPU + target interface combination.
J-Link>
I still don’t see any log output from either JLinkExe or JLinkRTTClient although now JLinkRTTClient does not show dots but that it is connected to process JLinkExe:
###RTT Client: Connection closed by J-Link DLL. Going to reconnect.
###RTT Client: Connecting to J-Link RTT Server via localhost:19021 . Connected.
SEGGER J-Link V6.34c - Real time terminal output
J-Link OB-SAM3U128-V2-NordicSemi compiled Jul 12 2018 11:44:41 V1.0, SN=682620304
Process: JLinkExe
Here’s my log. Interface is SWD.
Otso-MacBook-Pro:~ ojousima$ JLinkExe
SEGGER J-Link Commander V6.22f (Compiled Jan 12 2018 16:19:34)
DLL version V6.22f, compiled Jan 12 2018 16:19:24Connecting to J-Link via USB…O.K.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 12 2018 16:05:20
S/N: 682971638
VTref = 3.300VType “connect” to establish a target connection, ‘?’ for help
J-Link>connect
Please specify device / core. : NRF52832_XXAA
Type ‘?’ for selection dialog
Device>NRF52832_XXAA
Please specify target interface:
J) JTAG (Default)
S) SWD
TIF>S
Specify target interface speed [kHz]. : 4000 kHz
Speed>4000
Device “NRF52832_XXAA” selected.Connecting to target via SWD
Found SW-DP with ID 0x2BA01477
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Cortex-M4 identified.
J-Link>
Yes, I get the same thing. I neglected to specify the device name and SWD after the connection. Now I am getting all of the debug output using JLinkRTTClient after connecting with JLinkExe.
