When I tried to update the firmware by going to the âUpdate Firmwareâ screen for the tag, I saw a screen that said, âLatest available Ruuvi Firmware version: v3.31.1â, âCurrent version: Ruuvi FW v.3.30.4+defaultâ. I clicked the âStart update processâ button, then put the sensor to updating mode. Then I clicked the âStart update processâ button. The green progress bar went from 0% to 100%, then the screen said, âUpdate successfulâ.
However, when I went to the âUpdate Firmwareâ screen again, I see the same message as before, âLatest available Ruuvi Firmware version: v3.31.1â, âCurrent version: Ruuvi FW v.3.30.4+defaultâ.
I tried it again (why not?), but still got the same result.
Is It possible that the tag being updated is different one than the one you are looking at in Ruuvi Station? The app expects to find a tag in update mode, but iOS app does not verify that the tag being updated is the same one as the one selected in Station. Itâs possible to have tags A and B, click update on A and end up updating B.
Yes, thatâs quite possible. I just tried it again and the update worked fine, so I suppose thatâs what happened.
Thanks for your helpful response and sorry for my confusion!
I presume you already know this, but it would be nice if the Ruuvi Station iOS app ensured that the tag that itâs updating is the same one thatâs selected in the app.
I have similar problem with IOS and I have only one Ruuvi tag. I had version v3.28.12. I updated it with Ruuvi app, and when I go to update firmware, it tells I have version: â*
I tried the same with manual update using nRF connect app and manually downloading the latest firmware from: http://ruuvi.com/software-update/
Still the same firmware version listed: â*
And suggestion to update to v3.31.1
I installed the old firmware back and tried the above steps few times, but could not get to v3.31.1.
Can you give instructions to me where to look for version number? I couldnât spot anything directly that made sense to share unless you mean the info in manufacturer data: Ruuvi Innovations Ltd. <0x0499>
Ilmeisesti Tagin sisÀlle tallennettu versio on jotenkin korruptoitunut.
Jos Tag toimii hyvin, asialle ei tarvitse tehdÀ mitÀÀn. Jos Tagin toiminnassa on ongelma, ota yhteyttÀ sales@ruuvi.com ja toimitamme uuden laitteen takuuvaihtona ja tutkimme mikÀ tÀssÀ yksilössÀ on vikana.
