Hi all,
I’ve bought a couple of used ruuvitags that were advertised as functional, but cannot connect in any way with the ruuvi station or the nRF connect
Removing the battery, pressing the reset or trying to go in bootloader mode ( R+B button) don’t affect the leds…they always stay on for 1-2 seconds and never blink
There is something I’m missing? What else I could check?
Have you tried putting new battery in to the devices? It’s possible that the batteries are at the end of their life and can boot the tag but don’t have enough power to operate radio anymore.
Hi Otso,
I measured both batteries and are about at 3.01V, so they should be fine
The seller didn’t mentioned about custom firmware, so I assumed they were ready to use, anyway I’m writing to him right now.
So in case they installed a custom firmware the only way to connect the ruuvitag and restore the original one is by using the devkit arduino shield?
Depends on the firmware, but if there is no bootloader you need SWD connection to tag. On older RuuviTags that practically requires the Ruuvi Devkit, on B6 and upwards you can use any SWD programmer with a Tag-Connect cable. https://lab.ruuvi.com/pinout/ has more information about the programming connectors.
I’ve checked and both are B6, nice to know that I can use other SWD programmer, I was already looking for the 6pin JTAG connector and the nRF52832 dev board.
This is a bit too much a “rabbit hole” for me, never expected to encounter those difficulties but I would like to resque the 2 Ruuvitag
Anyway I’ll wait for a reply from the seller and then let you know as soon I’ve new info
The seller shortly replied me that they should have the standard firmware, but at this point I’m not sure if trust him
I did a short video showing how the led turn on, trying to reset and going in bootloader mode…there is something that I can try before resorting to the wired connection?
The serial number makes me think that the firmware is something else than standard Ruuvi Firmware, there isn’t really anything that would produce a 7 decimal digit serial on Ruuvi Firmware.
I can’t come up with anything else than flashing the original factory firmware on those tags, they seem to be fine visually.
Do you know what’s the origin of your batteries? 4.0 V seems really high for a li-ion coin cell, I don’t think I’ve ever measured over 3.5 V on any battery shipped by Ruuvi.
They are CR2477
I was pondering about the 4.0V, indeed too high, and in the end it was just a false reading from my multimeter (with an almost flat battery )
Measured again and are 3.2 and 3.1V.
Anyway the batteries are not the issue, I’ve also tried to supply 3V using a lab power supply but din’t change anything
In the end I’ve decided to try the wired connection option
Since you mentioned that from B6 is possible to use any SWD programmer and I just need to restore the original firmware (not developing anything) do you have some cheap options to suggest?
Otherwise I’ll buy the Ruuvi DEVKIT, is a bit pricey for my need but as soon I recover the ruuvi I’ll probably sell it to other users.
Thanks the swift reply Otso, I thought about it a bit about it and I’ll probably bite the bullet and buy the official Ruuvi devkit and a brand new Ruuvitag.
In the end this is the fastest way to have something to working with and go on with my project
Are there public coupons code active for a first time buy on the official shop?
update: I’ve received the devkit + 1 new ruuvitag (fast shipping!) today and now I’m trying to undestand how to flash the firmware.
I’ve to admit that I’ve almost no knowledge about C, compiling, hw debugging, ect so I’m a bit lost.
What I did until now:
ruuvi on the shield+devkit and connected via usb
installed Segger embedded studio
git cloned last ruuvi firmware from github and downloaded the Nordic Semiconductor SDK nRF5_SDK_15.3.0_59ac345 on project folder
I suppose I need to compile the firmware and then flash by using the “connect J-link” on SES, but when I try to build the project I get a missing file error from the main.c: task_acceleration.h: No such file or directory
I’m on windows, do I need to switch on a unix environment?
Be sure to power cycle the tag (remove battery) to make sure that the debug interface is turned off afterwards, otherwise your batteries will drain quickly. If the erase all command doesn’t work, you have confirmed that there’s some other firmware and you can run nrfjprog --recover
If you want to compile the firmware yourself, it should be doable on windows but it’s possible that project configuration needs to convert some / to \\ or \
In the end I managed to restore a ruuvitag with the alpha 3.17.1 firmware and SES (compiling worked fine with this version) by following this tutorial on lab.ruuvi
The other one restored flawlessy to 2.5.9 using the nrf command line you suggested, so both are now finally working!
Digging down into this I founded a lot of interesting posts and articles and tutorials (most written by you @otso) I guess I’ve a lot to study and play with in the next weeks
Thanks again for the support!
