Moi!
Voisiko mobiililaitteella synkronoidut datapisteet saada Ruuvin pilveen? Minulla on yksi Ruuvi kompostorissa pihan laidalla ja gateway ei yllä sinne. Voin hyvin kerran viikossa synkata kännykällä Ruuvin tiedot kompostorilta, mutta ne eivät välity pilveen, ja pidemmän ajan historia jää siksi pois.
Onko ollut harkinnassa lisätä toimintoa, joka toteuttaisi tämän tempun, eli manuaalisen synkronoinnin yhteydessä puskisi datan eteenpäin arkistoitavaksi? Tämä voisi samalla siirtää muutkin mobiililaitteen lukemat tiedot pilveen, jos vaikka osa tägeistä ei ole ihan gatewayn kantamalla mutta kännykkä kuitenkin pystyy ne lukemaan.
Google translates as: Hi!
Could the data points synchronized with a mobile device be uploaded to the Ruuvi cloud? I have one Ruuvi in ​​a composter at the edge of the yard and the gateway doesn’t reach it. I can easily sync Ruuvi data from the composter with my mobile phone once a week, but they are not transmitted to the cloud, and therefore the longer-term history is lost.
Has anyone considered adding a function that would implement this trick, i.e. push the data forward for archiving during manual synchronization? This could also transfer other data read by the mobile device to the cloud, if some of the tags are not quite within range of the gateway but the mobile phone can still read them.
[/quote]
TBH, I assumed this would have been an existing feature of the mobile app, since running a manual sync from the tag’s local history via the app to the cloud doesn’t tax any resource-limited IoT components (as opposed to having the gateway do it).
My use case is a remote location where the internet sometimes goes offline for days, but the same feature would help here too.
I assumed this would have been basic feature when buying the gateway. Currently all the data is only in my cellphone instead of the cloud. To me this is backwards. Of course all the data should be shown in cloud GUI. We have 20 sensors in 16 apartments and we can’t setup gateways in a way that all could be read. Few apartments are always unreachable, but they can easily be read manually with phone.
Even better would be that we would get data into cloud also from phones that use the shared sensors.
Tämä on nyt mietinnässä että onko tämä dealbreaker koko gatewaylle vai pelkälle pilvelle.
Yes, this would be super helpful! Not to mention a very logical approach, as the data is already on an app, on a device with a web connection.
Monitoring a location without a constant wifi connection (and often temporarily out of power altogether) so the gateway is not really a viable option. Visiting frequently with a mobile phone would solve the issue easily.
I can live without immediate alerts, but getting the data & history into cloud for sharing purposes without everyone needing to sync themselves is such a simple solution.
