i have just started getting this alert. I’m not sure why i’d be getting this. Any ideas?? Temperature sensor [20], Low battery alarm: Warning
Hello @Carolyn_Muegge-Vaugh ,
Thanks for your message and welcome to the forum!
In Ruuvi Station app, this means that your RuuviTag battery is getting low and you should consider replacing battery soon to keep the measurement data updating to the app.
The app warns you about low battery level depending on the temperature, as follows:
Below –20 °C (–4 °F): 2.0 V
–20 … 0 °C (–4 … 32 °F): 2.3 V
Above 0 °C (32 °F): 2.5
We recommend using se a high-quality CR2477 or CR2477T battery from a reputable manufacturer with RuuviTags.
