Google translates as :I have 4 RuuviTags with the latest firmware updated.
I bought two new ones before Christmas and one of them doesn’t sync if there is a longer time between syncs. Is it a week or two, but the problem is only in one Tag. Android as a phone.
Synchronize
Connecting…
Bluetooth charging: up to about 1350 goes fast, varies in both directions with each attempt, and then the number does not increase at all.
Press X to get “No connection”
In the other three, the same that the number is four digits very quickly, but after that it downloads slowly but surely and the number increases. This one too is such that every day if you synchronize it, it
seems to work.
Marko: Hi @OH7RX , thanks for your message and sorry for the trouble.
If the sensor’s firmware is up to date, it could be something else. Is there an iOS device in your household with Ruuvi Station and the sensor in question paired?
I remember coming across such cases once in a while, then that freeze happened at the top end of the measurement sequence number, somewhere around 50xxx. There could be a similar situation here.
OH7RX:All Tags have the same firmware, v3.31.1+default, the latest you can find.
I have not paired that tag anywhere else, only to one Android phone. And I only have Tags, not other Ruuvi products. When you remove the battery, it starts to work, but you lose its uncharged history.
Otso: RuuviTag tries different connection settings, after half a minute the tag switches to the most reliable mode, which also uses more battery. Does RuuviTag sync at a reasonable speed if you wait a while?
