For some time now I've been trying to build my own gateway PCB, using the documentation provided on your website. I'm stuck regarding the flash memory part number used in the product; I can't find it. Is it possible to get it?
Thank you for your support.
This is one ok option you may want to check out: https://www.verical.com/pd/winbond-serial-nor-flash-W25Q128JVSIQ-4369804
Also other compatible memory chips supported by ESP32 should work without problems.
Thank you for your help.
