Sorry if this is already discussed, but didn’t find topic so opening new one.
Basicly I have Raspberry Zero W which works as Pi-hole for now and that function is planned to stay… I was just wondering that if no need for Grafena etc. just reading sensor data and sending it to the openweathermap as station ( Weather Stations - OpenWeatherMap ), would Zero W has enought power to do that alogside of working as Pi-hole?
Also what would be simplest / easiest and most lightest (in resources wise) way to do that. And also, since I didn’t yet read lot of information from openweathermap, if you have experience from it… Will it allow to sent data as “weather station” when not all data availabale (wind, etc.)?
I hope it is possible to join by using only RuuviTag and there would be some easier solution I would find by myself. After all if more data could be offered there, that would lead to better forecast, more accurate data overall etc. But with that said, is it normal to send pressure data as actual (I would think it is) and then service will decide wether or not to compensate that as location hight etc…
