Is there a sensor available or how would one mount an existing sensor to heating pipes used in water-flow home heating systems? Measurement range roughly 15-50 celcius and pipes are 1-2" in diameter.
The plastic enclosure of RuuviTag insulates the sensor from the pipe heat, so itβs not really feasible to measure water temperature inside pipes or pipe surface temperature with RuuviTags.
We have done some trials with external sensor probes, but those are in prototyping stage as of right now
