I can not connect to my Ruuvi tag from a Debian laptop. Connection working from Android phone, so the tag is alive.
For scanning tags, I tried to use Python and NodeJS libraries. Nothing works. I am not experienced in conf Bluetooth settings. The laptop is also rather old Lenovo T420. Is it possible that Bluetooth chip is incompatible with the Ruuvi tag?
Here are some clipboard data from cli.
hcitool dev
Devices:
hci0 NN:NN:NN:NN:NN:NN
hciconfig
hci0: Type: Primary Bus: USB
BD Address: NN:NN:NN:NN:NN:NN ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN ISCAN INQUIRY
RX bytes:6588 acl:0 sco:0 events:527 errors:0
TX bytes:10256 acl:0 sco:0 commands:397 errors:0
root@lpt2:~# hcidump
HCI sniffer - Bluetooth packet analyzer ver 5.50
device: hci0 snap_len: 1500 filter: 0xffffffffffffffff
< HCI Command: Reset (0x03|0x0003) plen 0
HCI Event: Command Complete (0x0e) plen 4
Reset (0x03|0x0003) ncmd 1
status 0x00
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0
HCI Event: Command Complete (0x0e) plen 12
Read Local Supported Features (0x04|0x0003) ncmd 1
status 0x00
Features: 0xff 0xff 0x8f 0xfe 0x9b 0xff 0x79 0x87
< HCI Command: Read Local Version Information (0x04|0x0001) plen 0
Read Local Version Information (0x04|0x0001) ncmd 1
status 0x00
HCI Version: 3.0 (0x5) HCI Revision: 0x2ec
LMP Version: 3.0 (0x5) LMP Subversion: 0x4203
Manufacturer: Broadcom Corporation (15)
< HCI Command: Read BD ADDR (0x04|0x0009) plen 0
HCI Event: Command Complete (0x0e) plen 10
Read BD ADDR (0x04|0x0009) ncmd 1
status 0x00 bdaddr E4:D5:3D:C7:37:E3
< HCI Command: Read Buffer Size (0x04|0x0005) plen 0
HCI Event: Command Complete (0x0e) plen 11
Read Buffer Size (0x04|0x0005) ncmd 1
status 0x00
ACL MTU 1021:8 SCO MTU 64:1
< HCI Command: Read Class of Device (0x03|0x0023) plen 0
HCI Event: Command Complete (0x0e) plen 7
Read Class of Device (0x03|0x0023) ncmd 1
status 0x00 class 0x000000
< HCI Command: Read Local Name (0x03|0x0014) plen 0
HCI Event: Command Complete (0x0e) plen 252
Read Local Name (0x03|0x0014) ncmd 1
status 0x00 name ‘lpt2’
< HCI Command: Read Voice Setting (0x03|0x0025) plen 0
HCI Event: Command Complete (0x0e) plen 6
Read Voice Setting (0x03|0x0025) ncmd 1
status 0x00 voice setting 0x0060
< HCI Command: Read Number of Supported IAC (0x03|0x0038) plen 0
HCI Event: Command Complete (0x0e) plen 5
Read Number of Supported IAC (0x03|0x0038) ncmd 1
< HCI Command: Read Current IAC LAP (0x03|0x0039) plen 0
HCI Event: Command Complete (0x0e) plen 8
Read Current IAC LAP (0x03|0x0039) ncmd 1
IAC 0x9e8b33 (General Inquiry Access Code)
< HCI Command: Set Event Filter (0x03|0x0005) plen 1
type 0 condition 0
Clear all filters
Set Event Filter (0x03|0x0005) ncmd 1
status 0x00
< HCI Command: Write Connection Accept Timeout (0x03|0x0016) plen 2
timeout 32000
Write Connection Accept Timeout (0x03|0x0016) ncmd 1
status 0x00
< HCI Command: Read Local Supported Commands (0x04|0x0002) plen 0
HCI Event: Command Complete (0x0e) plen 68
Read Local Supported Commands (0x04|0x0002) ncmd 1
status 0x00
Commands: ffffff03feffefffffffef1ff20fe8fe3ff78fff1c00000001
< HCI Command: Write Simple Pairing Mode (0x03|0x0056) plen 1
mode 0x01
Write Simple Pairing Mode (0x03|0x0056) ncmd 1
status 0x00
< HCI Command: Write Inquiry Mode (0x03|0x0045) plen 1
mode 2
Write Inquiry Mode (0x03|0x0045) ncmd 1
status 0x00
< HCI Command: Read Inquiry Response Transmit Power Level (0x03|0x0058) plen 0
Read Inquiry Response Transmit Power Level (0x03|0x0058) ncmd 1
status 0x00 level 0
< HCI Command: Read Local Extended Features (0x04|0x0004) plen 1
page 1
HCI Event: Command Complete (0x0e) plen 14
Read Local Extended Features (0x04|0x0004) ncmd 1
status 0x00 page 1 max 1
Features: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00
< HCI Command: Set Event Mask (0x03|0x0001) plen 8
Mask: 0xfffffbff07f8bf1d
Set Event Mask (0x03|0x0001) ncmd 1
status 0x00
< HCI Command: Read Stored Link Key (0x03|0x000d) plen 7
bdaddr 00:00:00:00:00:00 all 1
Read Stored Link Key (0x03|0x000d) ncmd 1
status 0x00 max 1 num 0
< HCI Command: Write Default Link Policy Settings (0x02|0x000f) plen 2
policy 0x0f
Link policy: RSWITCH HOLD SNIFF PARK
Write Default Link Policy Settings (0x02|0x000f) ncmd 1
status 0x00
< HCI Command: Read Page Scan Activity (0x03|0x001b) plen 0
Read Page Scan Activity (0x03|0x001b) ncmd 1
status 0x00 interval 2048 window 18
< HCI Command: Read Page Scan Type (0x03|0x0046) plen 0
Read Page Scan Type (0x03|0x0046) ncmd 1
< HCI Command: Delete Stored Link Key (0x03|0x0012) plen 7
Delete Stored Link Key (0x03|0x0012) ncmd 1
status 0x00 deleted 0
< HCI Command: Write Scan Enable (0x03|0x001a) plen 1
enable 3
Write Scan Enable (0x03|0x001a) ncmd 1
status 0x00
< HCI Command: Write Class of Device (0x03|0x0024) plen 3
class 0x1c010c
Write Class of Device (0x03|0x0024) ncmd 1
status 0x00
< HCI Command: Write Local Name (0x03|0x0013) plen 248
name ‘lpt2’
Write Local Name (0x03|0x0013) ncmd 1
status 0x00
< HCI Command: Write Extended Inquiry Response (0x03|0x0052) plen 241
fec 0x00
Complete local name: ‘lpt2’
TX power level: 0
Unknown type 0x10 with 8 bytes data
Complete service classes: 0x110e 0x110c 0x1112 0x1108 0x1133 0x1132 0x112f 0x1104 0x1106 0x1105 0x110a 0x110b
Unknown type 0x07 with 16 bytes data
Write Extended Inquiry Response (0x03|0x0052) ncmd 1
status 0x00
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7
type 0x01 (active)
interval 10.000ms window 10.000ms
own address: 0x00 (Public) policy: All
LE Set Scan Parameters (0x08|0x000b) ncmd 1
status 0x01
Error: Unknown HCI Command
< HCI Command: Inquiry (0x01|0x0001) plen 5
lap 0x9e8b33 len 8 num 0
HCI Event: Command Status (0x0f) plen 4
Inquiry (0x01|0x0001) status 0x00 ncmd 1
HCI Event: Inquiry Complete (0x01) plen 1
status 0x00
