Is anyone using RuuviTags in SmartThings? Wondering if somehow I could get readings visible to ST. Bluetooth radio in ST hub is deactivated, so they can’t connect directly.
This was the only discussion I found: https://community.smartthings.com/t/ruuvitag-environmental-sensors/162349
I found this old thread. Has there been any progress in integrating RuuviTags and Smartthings?
Hi @Control ,
You could try Home Assistant which, I believe, is able to integrate both Smartthings and RuuviTags as well as Ruuvi Gateways.
