Hi @ARosti
Youāre right, pressure should be in hPa, not in Pa. It should be fixed in release 0.2.7
Hi @ARosti
Accuracy should be properly handled in release 0.2.7, so you can change amount of decimals by creating a new custom measure (for now, accuracy canāt be change on default measures ⦠can change in futur
I have homeassistant installed in raspberry. Now trying to install RuuviTag Discovery and got this error: āThe command ā/bin/ash -o pipefail -c npm install --no-audit --productionā returned a non-zero code: 1ā.
What is wrong with this?
Hi @ml
I just tried a fresh install and I did not encounter any problem.
How did you install RuuviTag Discovery? Following https://github.com/balda/ruuvitag-discovery/blob/master/DOCS.md instructions?
And can you give me your raspberry model? and which version of Home Assistant you are using?
Thanks
Tested and working well. Still easy to understand and use also
Now I just need to start using these new labels in Home Assistant so it will be much cleaner.
Oh dear! Something seems to be wrong on the latest 0.2.8 version. I tried to upgrade my Raspbian installation and I thought I must have done something silly so I ended up installing ubuntu server since that was something I planned to do at some point anyway. But even after clean install I ended up getting same kind of problems that seem to be related to dependencies. Especially node-gyp gives errors. What could be the reason?
Error log:
0 info it worked if it ends with ok
1 verbose cli [ ā/usr/bin/nodeā, ā/usr/bin/npmā, āstartā ]
2 info using npm@6.14.4
3 info using node@v10.19.0
4 verbose run-script [ āprestartā, āstartā, āpoststartā ]
5 info lifecycle ruuvitag-discovery@0.2.8~prestart: ruuvitag-discovery@0.2.8
6 info lifecycle ruuvitag-discovery@0.2.8~start: ruuvitag-discovery@0.2.8
7 verbose lifecycle ruuvitag-discovery@0.2.8~start: unsafe-perm in lifecycle true
8 verbose lifecycle ruuvitag-discovery@0.2.8~start: PATH: /usr/share/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/ubuntu/ruuvitag-discovery/node_modules/.bin:/usr/local/sbin>
9 verbose lifecycle ruuvitag-discovery@0.2.8~start: CWD: /home/ubuntu/ruuvitag-discovery
10 silly lifecycle ruuvitag-discovery@0.2.8~start: Args: [ ā-cā, āNODE_ENV=production node index.jsā ]
11 silly lifecycle ruuvitag-discovery@0.2.8~start: Returned: code: 1 signal: null
12 info lifecycle ruuvitag-discovery@0.2.8~start: Failed to exec start script
13 verbose stack Error: ruuvitag-discovery@0.2.8 start:NODE_ENV=production node index.js
13 verbose stack Exit status 1
13 verbose stack at EventEmitter. (/usr/share/npm/node_modules/npm-lifecycle/index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:198:13)
13 verbose stack at ChildProcess. (/usr/share/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:198:13)
13 verbose stack at maybeClose (internal/child_process.js:982:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
14 verbose pkgid ruuvitag-discovery@0.2.8
15 verbose cwd /home/ubuntu/ruuvitag-discovery
16 verbose Linux 5.4.0-1028-raspi
17 verbose argv ā/usr/bin/nodeā ā/usr/bin/npmā āstartā
18 verbose node v10.19.0
19 verbose npm v6.14.4
20 error code ELIFECYCLE
21 error errno 1
22 error ruuvitag-discovery@0.2.8 start:NODE_ENV=production node index.js
22 error Exit status 1
23 error Failed at the ruuvitag-discovery@0.2.8 start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
I was able to solve this myself. I ended up installing Raspberry Pi OS back because with Ubuntu I couldnāt even get the bluetooth adapter working. After playing with countless of versions of Node.js and npm and dependencies I ended up in combination that would start up. I tried to keep track what Iām doing so I would be able to write exact steps here incase someone else has the same problem but I lost track. Gained some good troubleshooting experience and learned not to mess with working system ![]()
What I might be doing wrong here as I seem to have some issue sending the messages to MQTT broker (if I have understood correctly how MQTT works)?
In the RuuviTag Discovery I have a total of three devices recognized. For one of these devices I have set a target to be HiveMQ.
In the log file it says that it is sending information to the configured target (Hive_MQTT):
[2021-06-01T21:31:15.684Z] [DEBUG] Broadcast to "Hive_MQTT"
[2021-06-01T21:31:15.686Z] [DEBUG] [MQTT] Publish on topic "Work/ruuvitag_d8b98aa8acac" message: {"id":"d8b98aa8acac","name":"RuuviTag d8b98aa8acac","field":"ruuvitag_d8b98aa8acac","measures":[{"label":"Temperature","field":"temperature","value":22.09,"measure":"temperature"}]}
But for some reason the message never gets there. I have manually opened a subscription to this topic and tested from Home Assistant to send a āHelloā which I then received in the subscription end. But I canāt get the messages showing in the terminal that are sent by these RuuviTags. Also Home Assistant doesnāt show these tags.
pi@raspberrypi:/home/ruuvitag-discovery/data $ mqtt sub -h XXX.s2.eu.hivemq.cloud -p 8883 -s -u XXX -pw -t 'Work/ruuvitag_d8b98aa8acac'
Enter value for --password (The password for authentication):
Hello
I have installed Rassbian OS to the Raspberry Pi 4 and then manually installed Home Assistant with virtual environment.
Br,
Jussi
Ended up installing Mosquitto and got this working with it. Didnāt know how to extract information from the JSON message (tag) so ended up creating topics for each field for every tag in the Home Assistant. I also created custom fields for rounding humidity percentage and this displayed correctly in the RuuviTag Discovery but it still sent information without rounding.
New to HomeAssistant and this works like a charm! I had tiny problems with installation but this was due to my low knowledge about home assistant. Have to study how to utilize this in node-red/ha.
Thanks a lot!
Article published about the Home Assistant and RuuviTags. Unfortunately not yet direct support for the Ruuvi gateway and HASS. https://ruuvi.com/connecting-ruuvitag-bluetooth-sensors-to-home-assistant/
