I can’t find information anywhere.
I pressed them a few times and didn’t notice anything, except, I noticed the temperature reading went up by 10 degrees fahrenheit, and it stayed there for 15+ minutes and then started dropping slowly back to normal. Not sure if that is button related or if I touched the sensor with my finger.
Thank you.
I’ve been having a problem with my tags. One of the tags is about 2 degrees Fahrenheit lower than the other two. The tags were all placed right next to each other for hours when this measurement was taken. I moved them to a different room and, again, one tag (Ernesto) is about 2 F lower than the other two. I reset them all, and still the same problem. Is this a faulty tag? Or is there a way to adjust it?
Thanks.
