I have one of these tags and was using for Bluetooth Mesh purposes. Since it was battery powered I was aiming to reduce the current consumption using various CONFIG permutations. But then, I found that the light_switch example from Nordic enables it as a LOW_POWER_NODE and it was then supposed to improve battery life. I changed the board into ruuvi_ruuvitag in the build configuration, built the firmware and flashed it onto the tag using a JLink debugger.
After flashing I could not see the mesh node on the NRF mesh mobile app. Then I was trying to reflash again but from then onwards my debugger was not detecting the tag anymore. It was giving me this error in VSCode
Flashing build to 682230353
west flash -d /home/jeason/mesh/hyp_mesh_tag/build --skip-rebuild --dev-id 682230353 --recover
– west flash: using runner nrfjprog
– runners.nrfjprog: Recovering and erasing all flash memory.
Recovering device. This operation might take 30s.
[error] [ Client] - Encountered error -21: Command recover executed for 5713 milliseconds with result -21
[error] [ Worker] - An unknown error.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
NOTE: For additional output, try running again with logging enabled (–log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 62: nrfjprog --recover -f NRF52 --snr 682230353
and this error on Nrf Connect Desktop Programmer.
I tried the same firmware on a nrf52DK nrf52832 and can say was working as intented. I tried using different NRF DK as debuggers to flash the tag was not working. I tried different cables, same result. Also tried different computers, no success.
Eventhough the tag does not appear of the mesh app or cannot be flashed, it is still drawing 0.45mA of current doing nothing. I assume that it means I have not fried the chip.
Is there any way to revive the tag??
