Ruuvi Station web page sorted differently for temperature and humidity
We have quite many Ruuvi tags. In the web page view when I switch between temperature, humidity and other views, the sensor cards get shuffled to different order. This is bit annoying, as we use two monitors and web browser windows to show temperature and humidity data of all of our rooms. Now it’s hard to read as sensors are not at same places on both screens. I think this changed in some resent update. Could also be because we have Tags with and without humidity sensor.
Hello @HenriP ,
Thank you for your message and your report, we are investigating this. The ordering of the cards in the list should not change, but the view can change according to selection and card size. Since there can be different sized cards, we are using a so called masonry logic to arrange them to a consistent view. This is a step towards flexible cards which allows you to choose any combination of measurements to be shown or hidden from any sensor card in the future.
Thank you for the answer, and for very nice looking data visualization page.
Indeed I noticed that cards might have slightly different sizes, as some are measuring data that some are not. For example Pro 3in1 Tag (measures temperature and humidity but not pressure) in temperature view shows in small font humidity and movements (2 things). But in humidity mode shows humidity, movements and temperature (3 things). Therefore changing card size.
Or apparently in temperature view temperature appears only as large font. But in humidity view humidity value is shown both large and small font. At least in history cards view.
So please try to keep card sizes consistent between all views.
Thank you,
1.2.8 update fixed this issue.
