Hi!
Anyone found a simple and easy solution to make graphs from Ruuvi Station .csv files? Like drag and drop. Or at least graphical user interface. Not messing too much with code.
Ruuvi csv -> ? -> Grafana?
I tried InfluxDB and Grafana. BUT. Importing csv to InfluxDB seems to be pain - tried to install Telegraf for Influx csv function but installation failed with some error. Damn.
Also converting times to match linux time seems sounds like hassle. https://www.influxdata.com/blog/getting-started-writing-data-to-influxdb/ . Damn.
Using CSV in Grafana https://grafana.com/grafana/plugins/marcusolsson-csv-datasource failed to Grafana not recognizing the pluings folder. Damn.
For background: I also tried to use a tablet with linux as gateway. But the bluetooth on that tablet does not work with the linux. Damn.
Tried to used Mac to collect the data from Ruuvi Tags. Seems the bluetooth is not compatible with OpenHab. Damn.
