I have successfully set up a gateway call (https://docs.ruuvi.com/ruuvi-station-app/gateway) to my Ruuvi Station. But instead of calling using defined interval, gateway is called constantly or second after second. What is wrong?
Hi @ARosti ,
@Denis_Andreev can take a look at this next week, @ARosti ping me or @Denis_Andreev if you don’t hear back by Tuesday,
Hi @ARosti,
if application is in foreground it will behave like you described - will send request to gateway on every registered signal from your RuuviTags. If it’s working in background then it will be activated accordingly with defined background scan interval. But unfortunately it won’t combine measurments from different sensors into one request. So for example if you have 3 sensors and you setup app to background scanning with 5 minutes interval then you should recieve 3 requests to gateway every 5 min.
Actually I have figured this out, and for some time in the background, the app called gw as described. But after some time in background, it seems that it started sending request like it was in foreground.
Unfortunately I cannot check this for now, since the Android phone where Ruuvi Station is installed is not in the same location I am, and it takes for a while before I can do further checking. It just sounds strange that app in background would somehow jump to foreground on its own.
I suggest this thread does not cause further investigations until I have gained access to the remote phone again to verify if the app is in foreground or not.
