I’m trying to connect my Ruuvi Gateway to a local broker (Apache ActiveMQ Artemis) with MQTT using TLS. Unencrypted connection works fine and also other clients are able to connect with MQTTS.
What version of TLS (and possibly cipher suites) does the Ruuvi Gateway support? When clicking on “Check” on Ruuvi GW setup I get “Validation failed
Failed to connect (Error 32784 (ESP_ERR_MBEDTLS_SSL_HANDSHAKE_FAILED))” and
Artemis logs show " javax.net.ssl.SSLHandshakeException: Received fatal alert: bad_certificate"
Also, I’m using Let’s Encrypt certificates which expire in 3 months so uploading a custom cert every x months is not really an option.
My broker supports TLSv1.2 and the following ciphers (this is from nmap output):
PORT STATE SERVICE
8883/tcp open secure-mqtt
| ssl-enum-ciphers:
| TLSv1.2:
| ciphers:
| TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (secp256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (secp256r1) - A
| TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256 (secp256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (secp256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (secp256r1) - A
| TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384 (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384 (prime256v1) - A
| TLS_ECDH_ECDSA_WITH_AES_128_GCM_SHA256 (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_128_GCM_SHA256 (prime256v1) - A
| TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA384 (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_256_CBC_SHA384 (prime256v1) - A
| TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA256 (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_128_CBC_SHA256 (prime256v1) - A
| TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (secp256r1) - A
| TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (secp256r1) - A
| TLS_ECDH_ECDSA_WITH_AES_256_CBC_SHA (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_256_CBC_SHA (prime256v1) - A
| TLS_ECDH_ECDSA_WITH_AES_128_CBC_SHA (prime256v1) - A
| TLS_ECDH_RSA_WITH_AES_128_CBC_SHA (prime256v1) - A
| compressors:
| NULL
| cipher preference: server
|_ least strength: A
Nmap done: 1 IP address (1 host up) scanned in 0.98 seconds
