For those seeking to have easy-to-use and troublefree experience hooking your openHAB home automation with your Ruuvi Tags using absolute excellent antenna of Ruuvi Gateway – you are in luck!
I have introduced binding for openHAB (requires 3.4.0 M1 or newer) which makes the integration seamless. You need MQTT broker (such as mosquitto), openHAB and the Ruuvi Gateway.
You can find the addon via the built-in openHAB marketplace, here is the entry with full instructions Ruuvi Gateway MQTT binding - Bundles - openHAB Community
