â ruuvi-collector.service - Ruuvi Collector service
Loaded: loaded (/etc/systemd/system/ruuvi-collector.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2020-08-22 05:43:30 UTC; 4s ago
Process: 16185 ExecStart=/home/usr/bin/java -jar /home/ruuvi-collector/target/ruuvi-collector-0.2.jar (code=exited, status=200/CHDIR)
Main PID: 16185 (code=exited, status=200/CHDIR)
log:
Aug 22 05:46:07 ubuntu systemd[1]: Started Ruuvi Collector service. Aug 22 05:46:07 ubuntu systemd[16228]: ruuvi-collector.service: Changing to the requested working directory failed: No such file or directory Aug 22 05:46:07 ubuntu systemd[16228]: ruuvi-collector.service: Failed at step CHDIR spawning /home/usr/bin/java: No such file or directory Aug 22 05:46:07 ubuntu systemd[1]: ruuvi-collector.service: Main process exited, code=exited, status=200/CHDIR Aug 22 05:46:07 ubuntu systemd[1]: ruuvi-collector.service: Failed with result âexit-codeâ.
Seems like something is wrong with that /home/usr/bin/java directory, but I canât figure it out. All help is appreciated, thanks!
As usually Java is installed in something like /usr/bin/java (the first part after ExecStart= should point to the installed java executable). Using the command which java in a terminal might also give you a clue for the right path.
Another thing to check that looks a bit unusual is the path after the -jar flag on the same line, which should be the path to the compiled jar file; verify that this is indeed the right full path.
The WorkingDirectory= is not strictly required, as the collector doesnât require a specific working directory, but typically itâs set to the same directory as the jar file (like you have it configured now)
Log says " Changing to the requested working directory failed:
Does /home/ruuvi-colletor/target exist? or should it be /home/RuuviCollector/target ?
I have found that having the ExecStart refer to a script allows additional control over operations including addition of logger, and waiting until influxdb to be actually ready to accept transactions rather than just the fact that it is running.
I use RestartSec=300 since 5 seconds doesnât give you enough time to take any corrective action and causes rather rapid looping if something is wrong. (like a space problem)
I would add a comment regarding the fact that JVM exits with code 143 when receiving. a sigTERM so SuccessExitStatus=143 prevents systems from considering that an error. Actually I havenât seen that happen, but then again I never STOP ruuvicollector.
Aug 23 07:48:35 ubuntu systemd[4238]: ruuvi-collector.service: Changing to the requested working directory failed: No such file or directory
Aug 23 07:48:35 ubuntu systemd[4238]: ruuvi-collector.service: Failed at step CHDIR spawning /usr/bin/java: No such file or directory
Aug 23 07:48:35 ubuntu systemd[1]: ruuvi-collector.service: Main process exited, code=exited, status=200/CHDIR
Aug 23 07:48:35 ubuntu systemd[1]: ruuvi-collector.service: Failed with result 'exit-code'.
I checked the paths:
ubuntu@ubuntu:~$ which java
/usr/bin/java
ubuntu@ubuntu:~$ whereis java
java: /usr/bin/java /usr/share/java /usr/share/man/man1/java.1.gz
ubuntu@ubuntu:~/ruuvi-collector/target$ ls | grep ruuvi-collector-0.2.jar
original-ruuvi-collector-0.2.jar
Could this be related to permissions? I am not familiar at all with Linux permissions stuff, but some search results suggested that the directories might not have sufficient rights.
ubuntu@ubuntu:~$ ls -l ruuvi-collector/target/ruuvi-collector-0.2.jar
-rwxrwxr-x 1 ubuntu ubuntu 4867035 Aug 12 08:07 ruuvi-collector/target/ruuvi-collector-0.2.jar
ubuntu@ubuntu:~$ ls -l /usr/bin/java
lrwxrwxrwx 1 root root 22 Aug 9 15:06 /usr/bin/java -> /etc/alternatives/java
The very first part of the ExecStart directive points to the executable to run, which is java in this case. After the first part (separated by spaces) comes the arguments, first of them is -jar which instructs the java executable to run a specified jar-file, which is specified in the third part (=second parameter) which is /home/ubuntu/ruuvi-collector/target/ruuvi-collector-0.2.jar. This one has the /home/ubuntu/ in the beginning as you have the jar file in your home directory. Java on the other hand is installed into the system directories, not your home directory.
