Ruuvi Air and Luminosity
Hi All,
I just received the Ruuvi Air here in the US ( a reminder: the USB plug adapter is European; so you need a US one). This works great so far!! I plan to use it and add it to my raspberry5/influxdb/Home Assistant set up soon, with ruuvitag GitHub code.
Checking that and the official specifications of the Ruuvi Air, I noticed that there should be some data package about a luminosity sensor? Is it present in this version of the Ruuvi Air, or for a later version?
Ok just saw this post Ruuvi air ble protocole - #3 by otso
Nevermind!
Congrats on your new Ruuvi Air! Currently, the Ruuvi Air does not include a built-in luminosity (light) sensor—only temperature, humidity, CO₂, and VOC sensors are present. The specifications mention luminosity as a potential future feature, but it’s not available in the current version. If you need light sensing, you might consider adding a separate sensor and integrating it into your Home Assistant setup.
