Any thoughts or ideas would be appreciated:
The tag has reset for some reason. The battery spike is caused by first measurement being read with unloaded battery, after the first transmission the battery voltage is measured under radio activity load
Thanks.
I reversed the cause / effect in the title.
As you can see from other graphs the tag was is a static environment.
Itβs a puzzlement
