Remember selected dashboard measurement
When opening Ruuvi Station Web, the dashboard always resets the measurement selector to “Not selected”.
It would be very useful if the web interface remembered the last selected measurement (Temperature, Humidity, Pressure, COâ‚‚, etc.) for each user.
This way, users would always return to the view they use most without having to reselect it after every login or page refresh.
As an alternative, this could also be implemented as a user setting such as “Default dashboard measurement”.
Hi, thanks for the suggestion, this might be a nice addition.
We already support this in URL on sensor page itself, you can for example open a specific sensor with specific measurement using an URL in format /sensorMAC?key=temperature&unit=C
Actually, I don’t want this to apply to just a single sensor, but to all the sensors displayed on the home page. Is there a way to have this from a direct link?
Maybe the best solution for your case would be to use the existing Visible measurements feature?
Read more about Visible measurements:
I’ve just noticed this feature. This is exactly what I needed for my 2 Ruuvi Air. Thank you!
