I have been using the Ruuvi tags for years with OpenHAB 2 / OpenHAB 3 with a great success.
Now when I unwillingly upgraded to the OpenHAB 4, the Ruuvi tags won’t work anymore.
I am able to list the tags - Bluetooth will find them. I am able to receive some incoming messages from the Ruuvi-tags. However, suddenly the arrival of these messages stops and then the OpenHAB “Bluetooth thing” goes red indicating an error stage.
To isolate the problem I have restarted and reinstalled the Bluetooth stack as well as the Bluetooth binding in the OpenHAB.
I have then reinstalled the whole system twice from the scratch with no other configuration included. Every time the same issue occurs.
Then I started to think what if this problem is not related to the OpenHAB, but the Linux and the Bluetooth.
If the problem is with the Linux, then I think this problem can be causing a lot of trouble other systems as well, not just OpenHAB.
I then decided to test it in node-red instead of OpenHAB. In node-red I would be able to see the raw data from the Bluetooth node. The problem exists in node-red as well. I can see few messages, but then out of the blue the stream of incoming messages from the Ruuvi tags stops.
I am now thinking that maybe the issue is in the operating system of in the Bluetooth stack or drivers.
This may also affect other platforms, such as Home Assistant, not just OpenHAB.
People keep thinking that this is a range issue.
I have two different but similar setup where this problem takes place.
Platform: Raspberry Pi 4 Model B Rev 1.1
Release = Debian GNU/Linux 11 (bullseye)
Kernel = Linux 6.1.21-v8+
OS: Debian 11.7 64 bit
I am using the RPi 4 internal Bluetooth adapter and external Bluetooth dongle.
“Bus 001 Device 004: ID 2550:8761 Realtek Bluetooth Radio”
I have not been able to test other Linux versions.
Openhabian (OpenHAB 3) has kernel version 5.x
Do You thin his could be the case?
