[code] sudo dpkg --configure -a
Setting up owftpd (2.8p15-1) âŠ
insserv: warning: script âmathkernelâ missing LSB tags and overrides
insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopped
insserv: loop involving service mathkernel at depth 2
insserv: loop involving service rpc_shellinaboxd at depth 1
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg: error processing owftpd (--configure): subprocess installed post-installation script returned error exit status 1 Setting up dbus (1.6.8-1+deb7u5) ... insserv: warning: script 'mathkernel' missing LSB tags and overrides insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopped insserv: loop involving service mathkernel at depth 2 insserv: loop involving service rpc_shellinaboxd at depth 1 insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility$allâ which can not be true!
dpkg: error processing dbus (âconfigure):
Setting up shellinabox (2.14-1) âŠ
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility `$allâ which can not be true!
dpkg: error processing shellinabox (âconfigure):
dpkg: dependency problems prevent configuration of owfs:
owfs depends on owftpd (>= 2.8p15-1); however:
Package owftpd is not configured yet.
dpkg: error processing owfs (âconfigure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of udisks:
udisks depends on dbus; however:
Package dbus is not configured yet.
dpkg: error processing udisks (âconfigure):
Setting up ntp (1:4.2.6.p5+dfsg-2+deb7u1) âŠ
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg: error processing ntp (--configure): subprocess installed post-installation script returned error exit status 1 Setting up openssh-server (1:6.0p1-4+deb7u2) ... insserv: warning: script 'mathkernel' missing LSB tags and overrides insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopped insserv: loop involving service mathkernel at depth 2 insserv: loop involving service rpc_shellinaboxd at depth 1 insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility$allâ which can not be true!
dpkg: error processing openssh-server (âconfigure):
dpkg: dependency problems prevent configuration of dbus-x11:
dbus-x11 depends on dbus; however:
dpkg: error processing dbus-x11 (âconfigure):
Setting up owserver (2.8p15-1) âŠ
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg: error processing owserver (--configure): subprocess installed post-installation script returned error exit status 1 Setting up mysql-server-5.5 (5.5.41-0+wheezy1) ... [ ok ] Stopping MySQL database server: mysqld. 150124 16:50:26 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 150124 16:50:26 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 150124 16:50:26 [Note] Plugin 'FEDERATED' is disabled. 150124 16:50:26 InnoDB: The InnoDB memory heap is disabled 150124 16:50:26 InnoDB: Mutexes and rw_locks use GCC atomic builtins 150124 16:50:26 InnoDB: Compressed tables use zlib 1.2.7 150124 16:50:26 InnoDB: Using Linux native AIO 150124 16:50:26 InnoDB: Initializing buffer pool, size = 128.0M 150124 16:50:26 InnoDB: Completed initialization of buffer pool 150124 16:50:26 InnoDB: highest supported file format is Barracuda. 150124 16:50:28 InnoDB: Waiting for the background threads to start 150124 16:50:29 InnoDB: 5.5.41 started; log sequence number 1595675 150124 16:50:29 InnoDB: Starting shutdown... 150124 16:50:30 InnoDB: Shutdown completed; log sequence number 1595675 insserv: warning: script 'mathkernel' missing LSB tags and overrides insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopped insserv: loop involving service mathkernel at depth 2 insserv: loop involving service rpc_shellinaboxd at depth 1 insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility$allâ which can not be true!
dpkg: error processing mysql-server-5.5 (âconfigure):
Setting up owhttpd (2.8p15-1) âŠ
insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility $all' which can not be true! insserv: exiting now without changing boot order! update-rc.d: error: insserv rejected the script header dpkg: error processing owhttpd (--configure): subprocess installed post-installation script returned error exit status 1 Setting up apache2.2-common (2.2.22-13+deb7u4) ... insserv: warning: script 'mathkernel' missing LSB tags and overrides insserv: There is a loop between service rpc_shellinaboxd and mathkernel if stopped insserv: loop involving service mathkernel at depth 2 insserv: loop involving service rpc_shellinaboxd at depth 1 insserv: Stopping mathkernel depends on rpc_shellinaboxd and therefore on system facility$allâ which can not be true!
dpkg: error processing apache2.2-common (âconfigure):
dpkg: dependency problems prevent configuration of libapache2-mod-php5:
libapache2-mod-php5 depends on apache2.2-common; however:
Package apache2.2-common is not configured yet.
dpkg: error processing libapache2-mod-php5 (âconfigure):
dpkg: dependency problems prevent configuration of php5:
php5 depends on libapache2-mod-php5 (>= 5.4.36-0+deb7u3) | libapache2-mod-php5filter (>= 5.4.36-0+deb7u3) | php5-cgi (>= 5.4.36-0+deb7u3) | php5-fpm (>= 5.4.36-0+deb7u3); however:
Package libapache2-mod-php5 is not configured yet.
Package libapache2-mod-php5filter is not installed.
Package php5-cgi is not installed.
Package php5-fpm is not installed.
dpkg: error processing php5 (âconfigure):
Setting up rsyslog (5.8.11-3+deb7u2) âŠ
dpkg: error processing rsyslog (âconfigure):
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing mysql-server (âconfigure):
dpkg: dependency problems prevent configuration of ssh:
ssh depends on openssh-server; however:
Package openssh-server is not configured yet.
dpkg: error processing ssh (âconfigure):
dpkg: dependency problems prevent configuration of apache2-mpm-prefork:
apache2-mpm-prefork depends on apache2.2-common (= 2.2.22-13+deb7u4); however:
dpkg: error processing apache2-mpm-prefork (âconfigure):
dpkg: dependency problems prevent configuration of apache2:
apache2 depends on apache2-mpm-worker (= 2.2.22-13+deb7u4) | apache2-mpm-prefork (= 2.2.22-13+deb7u4) | apache2-mpm-event (= 2.2.22-13+deb7u4) | apache2-mpm-itk (= 2.2.22-13+deb7u4); however:
Package apache2-mpm-worker is not installed.
Package apache2-mpm-prefork is not configured yet.
Package apache2-mpm-event is not installed.
Package apache2-mpm-itk is not installed.
apache2 depends on apache2.2-common (= 2.2.22-13+deb7u4); however:
dpkg: error processing apache2 (âconfigure):
dpkg: dependency problems prevent configuration of phpmyadmin:
phpmyadmin depends on libapache2-mod-php5 | libapache2-mod-php5filter | php5-cgi | php5-fpm | php5; however:
Package php5 is not configured yet.
dpkg: error processing phpmyadmin (âconfigure):
Errors were encountered while processing:
owftpd
dbus
shellinabox
owfs
udisks
ntp
openssh-server
dbus-x11
owserver
mysql-server-5.5
owhttpd
apache2.2-common
libapache2-mod-php5
php5
rsyslog
mysql-server
ssh
apache2-mpm-prefork
apache2
phpmyadmin
pi@raspberrypi / $
[/code]
