Possibility to change default view setting per sensor type on android
Now when default can be changed per sensor to customize the values that are visible. It would be also cool to be able to modify the default per sensor type for all sensors that use default view. As I don’t really care/need movement information so by default I would like to change it for all to be something more useful for me. It’s pretty much clicking around to change movement off from +10 ruuvi Tags. As most of my sensors will not move or if they do then walls are moving. So I could have a movement not being on by default and add it to be visible for one sensor by selecting not to use default.
Anyway it’s really nice feature that default can now be modified. Keep up the good work!
