There’s no ticket system for questions, so sometimes things slip through especially on Slack. On forum we get new post notifications so it’s easier to check if there’s a reply already.
NFC works on 2.5.9, this is tested on factory with every device.
Depends on the environment, battery will read lower at colder temperatures. Most reliable indicator for the low battery is reboots as seen in measurement sequence counter, such as here:Grafana
Thanks for the battery details @dgerman
2.5v was answer i was trying to track down
My battery is at 2.65 and before the update to 2.5.9 i was able to get an ID from NFC but now i cannot get anything.
Is there a correct way to test the NFC?
My phone is Iphone XS Max and i have tried updating a few times but nothing seems to get NFC working
ok finally got it working, had to hold the ruuvitag at top of phone (notch end) and use a different nfc reader (NXP Tagwriter) because Decode only showed ID
Thanks @henri for letting me know about slack, I went back and checked and see the forum feeds into slack. The forum was much more effective at resolving issue so think i will stick with it.
