Multiple Gateways
Can I attach two or more Gateways to a single account? Why would you want to? Primary home and a vacation home. Outbuildings are too far away for the BlueTooth to reach (but they have internet access).
Ruuvi Gateways are not linked to your account. They listen to nearby Ruuvi sensors and relay their data to the cloud from where their owner can read the data from. So basically you can use any number of Ruuvi Gateways. Their ranges can even overlap with each other if you wish (multiple gateways to cover the whole property for example). The cloud is designed to discard duplicated data.
Thank you so much for such a clear and detailed response. These don’t seem to be well known in the US, but I’m finding so many uses for them and am now going to buy more sensors and probably at least one more Gateway.
Thank you I had he same question.
