Mounting Ruuvi Air in a RV / camper van?
Has anyone found a good solution to mount the Ruuvi Air securely in an RV or camper van?
Desired qualities are 1) allow the Ruuvi Air to function properly, 2) be secure from vehicle movement, and 3) be out of the way during every day activities in the limited space, 4) have access to USB-C power.
Ruuvi Tags are easy to mount in RVs (either using VHB tape to a wall, or the screw holes in the Ruuvi Tag Pro). They are also frequently used with the Victron Cerbo GX integration.
Will the Ruuvi Air operate properly if mounted upside down? If so, perhaps somehow mounting it underneath an upper cabinet might work.
The Ruuvi Air appears much harder to use in RV, but with wildfires and internal CO2 buildup affecting air quality it would be very useful.
I found one 3D-printable mount but it isn’t the best design for an RV: Ruuvi Air Wall Mount by ATK-tulostaja | Download free STL model | Printables.com
Hi @Stormwind ,
To answer your question about upside-down installation: yes, Ruuvi Air can operate in any orientation, as long as the sensor intake remains unobstructed to ensure reliable measurements.
