Seamlessly blend Monitor One’s robust features with Ruuvi Tags’ versatility for enhanced insights.
Story
This project enables you to transmit Ruuvi tag measurements to the Particle cloud using Monitor One.
Ruuvi Tags
With Ruuvi sensors you can measure temperature, air humidity, air pressure and movement at home, in your hobbies, or at work.
You can find them at https://ruuvi.com/.
Particle Monitor One
A Field-Ready, Yet Customizable IoT Gateway. Track and manage assets with reliable and dynamic cellular connectivity (LTE CAT 1/LTE CAT M1) and BLE.
Read more about them here: Monitor One - A Rugged and Customizable IoT Gateway | Particle.
How this project works
Using BLE on the Monitor One, the firmware provided with this project scans for Ruuvi tags and sends the first tag found to the Particle Cloud.
Now, you can send this information to the Web Service of your choice via Particle Webhooks.
The cloud
Even if you do not configure any webhook, your Monitor One will publish this information to the cloud every now and then, depending on its configuration.
Use the Particle cloud console at https://console.particle.io/ to see it:
You can also request the information at any time with the {“cmd”:“get_loc”} command:
Wrap up
This project supports one Ruuvi tag but you can add as many as you like by modifying the code.
The code can also be used on other Particle devices like Argon (Wi-Fi), Photon 2 (Wi-Fi), Boron (Cellular), and Tracker One (Cellular).
Thank you!
