Initial setup of device with DevKit
we built completely new PCB based on ruuvitag. First problem we faced is how to perform initial setup (bootloader etc) of new device. We have DevKit and because our PCB is with different placing, we can’t put our device on the top of ruuvitag shield, so we connected DevKit and new device directly (wires connected to header on DevKit and soldered on device side.
Can you please with initial device setup. Can we execute initial setup with Segger Embeded Studio and J-link for all components (bootloader, soft device and app) or we should take another approach?
Thx in advance,
Regards,
Sinisa
Regarding your “wire to DevKit” problem: have you considered having pads on your board for a https://www.tag-connect.com/product/tc2030-ctx-nl-6-pin-no-legs-cable-with-10-pin-micro-connector-for-cortex-processors or legged version
In this moment we are using DIY cable for connection and we will order a tag-connect, but real and urgent issue is how to perform initial bootloader and application deployment to “blank” device.
Hello @sbajsic,
Our blog post https://blog.ruuvi.com/preparing-binaries-2b76ab734a7e and latest makefile at https://github.com/ruuvi/ruuvi.firmware.c/blob/master/src/Makefile might be helpful to you.
Nordic Semiconductor also has a lot of resources which are valid for all nRF52 devices.
Please also note https://ruuvi.com/terms/can-or-cant/ when making your own devices, especially related to certifications and open-source licensing of derived products.
