DOlre
1 April 2022 14:57
1
Hi guys, I am trying to write ruuvi data to influx to prove a use case in the Volatile Gas inudstry.
I am using this to post in influx:
Test curl command:
Database is visible by the python code (added some debuggind code):
Data is being posted by code:
Influx is also receving successful Post connections:
But when I query ruuvi db in influx, it’s empty.
Am I missing anything? Not sure why my db is empty.
It looks like everything should just work… But I’m unsure. Am I missing anything?
otso
5 April 2022 07:29
2
The last select should probably be SELECT * FROM ruuvi_measurements
, database name is “ruuvi” and table name is “ruuvi_measurements” by default in the ruuvitag-sensor library if I remember correctly.
InfluxDB not receiving data. I’ve recently had to reinstall HA on my RasPi because the SDCard broke down, so I installed on Raspbian.
DOlre
7 April 2022 16:23
4
Thank you - I totally somehow missed this.
It all works now.
I’ve recently had to reinstall HA on my RasPi because the SDCard broke down. .
How old was SD? what brand?
