Incorrect temperature reading
I placed my RUUVI Tag in my freezer its reading a steady 79*F not actual freezer temperature Why?
Hi, do you have more than on sensor? If you take the sensor to your hand does the temperature change? You can also scan the sensor with NFC to identify it.
Typically in these cases sensor is not the same as placed in fridge or freezer.
