I tried to calibrate humidity measurement following this topic https://blog.ruuvi.com/humidity-sensor-673c5b7636fc and the measurements I receive are around 69%, 70% and 69% and temperatures 23,7 - 23,9 C. I tried several different containers, with and without lids, different amount of salt and water, and still the humidity is always between 68 - 71% even after keeping the container unopened for several weeks. The real humidity should be 75%, so is the difference still within normal variations and within RuuviTag’s measurement accuracy and therefore safe to calibrate all tags to 75%, or should I calibrate them to a bit lower value?
Using iOS ruuvi app v. 0.5 (19), tags running in firmware 3.28.12
Thanks, Mikko
. We have had discussion with Bosch regarding humidity accuracy and so far each device which has been showing “wrong” values have been tested to be OK. Did you open enclosures or were the enclosures closed during this testing?
