I am encountering a strange malfunction of Ruuvi gateway on firmware 1.24.4. The gateway send first/couple of HTTP POST correctly to customer server, but it fails after that. There are about 60-70 BLE devices around the office. So the payload is a bit big. log is as below:
I (434553) http: [adv_post_task/1] ### HTTP POST to URL=http://192.168.202.237:7071/api/Ruuvi/GW_VAASA
I (434555) http: [adv_post_task/1] HTTP POST DATA:
data payload here
I (435145) TRANS_TCP: [adv_post_task] hostname ‘192.168.202.237’ resolved to 192.168.202.237
E (435257) http: [adv_post_task/1] main/http.c:341 {http_async_poll}: ### HTTP POST to URL=http://192.168.202.237:7071/api/Ruuvi/GW_VAASA: failed, err=28675 (ESP_ERR_HTTP_WRITE_DATA)
I (435268) LEDS: [adv_post_task/1] ### leds_indication_network_no_connection
I (435272) LEDS: [adv_post_task/1] LED: Start blinking, interval: 200 ms, duty cycle: 50%
I (435437) ruuvi_gateway: [main/1] free heap: 127556
Update: When set the filter on to only Ruuvi tags. The gateway seems to send payout correctly. However, the goal of the project is to collect data from hundreds (even thousand) of sensors around. Is that just out of Ruuvi gateway’s capacity?
From netcat, I could see the data payload was not always send as full. It got cut and left out. From the screenshot could observe that the old payload ended with only partial data, then new payload came.
Can anyone help?
