How to flash custom firmware to device?
Hi guys,
since about two years I’m a user of some of those wonderful Ruuvi Tags. Brilliant things!
Now I have some ideas to modify the firmware for my specific application.
I had a look around and found the series of blogposts that describes certain features of the firmware and how to modify it: https://ruuvi.com/ruuvi-firmware-part-1-sleep/
Unfortunately the blogposts do not very well cover the actual process of flashing the new firmware to the device and what kind of hardware is required.
So far I understood that either I need a Ruuvi Dev Shield or that I can somehow connect a cable directly to the Ruuvi Tag.
Is there any blogpost or howto that describes the actual process of flashing a custom firmware to the Ruuvi Tag and what is needed hardware wise?
Thank you
Henry
Our RuuviLab article has the hardware connection information: RuuviLab | DevShield User Manual
You can also use Tag-Connect cables for the SWD connection for wired programming and debugging, but in practice having the target board zip-tied in place is very helpful.
On firmware side, we have a article about the general principles how creating a binary and DFU package, although it is a few years old so some details such as soft device version is out of date.
More recent blog post covers bootloader creation https://ruuvi.com/ruuvi-firmware-part-12-bootloader/
Readme also has details on how the makefile of the project creates the binaries and how to flash them.
