How can I use the USER API?
I want to test the these endpoints from the docs using my api key but I always get this
“result”: “error”,
“error”: “Unauthorized request.”,
“code”: “ER_UNAUTHORIZED”
I did everything right. Can someone help me?
Hello, can you show exact CURL commands that give you this error? Here’s a sample, note that dhv743unoc.execute-api.eu-central-1.amazonaws.com can be replaced with network.ruuvi.com:
  1. Get verification token:
curl --location 'https://dhv743unoc.execute-api.eu-central-1.amazonaws.com/register' \
--header 'Content-Type: application/json' \
--data-raw '{"email":"otso@ruuvi.com"}'
    "result": "success",
    "data": {
        "email": "otso@ruuvi.com"
  1. Verify email by sending the token JWM6, get authorization token:
curl --location 'https://dhv743unoc.execute-api.eu-central-1.amazonaws.com//verify?token=JWM6'
    "data": {
        "email": "otso@ruuvi.com",
        "accessToken": "753135/4sXXXXq",
        "newUser": false
  1. Use accessToken to read subscription history:
curl --location 'https://dhv743unoc.execute-api.eu-central-1.amazonaws.com/subscription' \
--header 'Authorization: Bearer 753135/4sXXXXq'
    "data": {
        "subscriptions": [
                "subscriptionName": "Business Starter",
                "maxClaims": 40,
                "maxShares": 80,
                "maxSharesPerSensor": 20,
                "maxHistoryDays": 1096,
                "maxResolutionMinutes": 1,
                "isActive": true,
                "startTime": 1690797997,
                "endTime": 1722333997
                "subscriptionName": "Pro",
                "maxClaims": 25,
                "maxShares": 40,
                "maxSharesPerSensor": 10,
                "maxHistoryDays": 731,
                "isActive": false,
                "startTime": 1688633497,
                "endTime": 1720169497
                "subscriptionName": "DEV",
                "maxClaims": 25,
                "maxShares": 40,
                "maxSharesPerSensor": 5,
                "maxHistoryDays": 720,
                "isActive": false,
                "startTime": 1673435374,
                "endTime": 1673608174
                "maxClaims": 25,
                "maxShares": 40,
                "isActive": false,
                "startTime": 1673435292,
                "endTime": 1673608092
