I was really wondering about things we can do with the Wirepas Connectivity. I would really like to see a implementation and if someone has done so had these questions :
How quickly can you use the wirepas connectivity to change the UUID broadcasted by beacon?
How much time the update takes if something is done through wirepas connectivity?
How its implemented, I mean how do we use wirepas connectivity to connect beacons to the internet?
So can we not create our own bluetooth mesh system, but too technical for me.
Bluetooth.com says this for example.
In contrast, a mesh network has a many-to-many topology, with each device able to communicate with every other device in the mesh (we’ll examine that statement more closely later on in the section entitled “Bluetooth mesh in action”). Communication is achieved using messages, and devices are able to relay messages to other devices so that the end-to-end communication range is extended far beyond the radio range of each individual node.
Personally I’ve used nRF52-DK as the USB dongle as well as some nRF52832-based USB dongles which were at prototype stage at the time, I think 52840 is supported, but please verify this with Wirepas.
Wirepas firmware comes under NDA and therefore the code cannot be shared publicly. As the code is under Wirepas licenses, it’s best to ask for the sources and support directly from them.
