Is there a way to set the Grafana refresh rate to 1 second???
Please let me know. Thank you.
5s is the lowest, you can try and edit the json by searching for "refresh": , but it will not accept anything less than 5 seconds.
this could help if you want to edit the config file:
I edited the ini file as per the articles and it didn’t work. The lower limit is still 5s.
Ok,
I figured it out…Under the properties gear for each dashboard, I was able to specify 1s for 1 second. Unfortunately, I had to do this for each dashboard. Not an issue for me but might be an issue for others.
Hi, everybody. I would like to know if you solved this issue.
I’m with grafana 7.3.4 and it’s impossible for me to change this value to 1s…
I’ve made the change in the .ini file (1s, 500ms, 100ms) but when I restart grafana server on my raspberry pi I can not modify to less than 5s, even in json model in dashboard settings…
Do anybody knows what I’m doing wrong???
Thanks a lot!!!
