Get Ruuvi data vai API when not in the local network
Hi there, I just got asked to help on a project where they are using some Ruuvi sensors in another city. Currently it looks like the gateway is in use for all 9 as the data can be found on at https://station.ruuvi.com.
I found in the docs that there is an API for collecting data, but you need to be in the local network. The city that the sensors are in is on the other side of the country, so I would prefer to not need to be there to set this up if possible.
Does anyone know how I can access the data when not in the local network to get β€œlive” updates for our website?
If not I think I will need to write a work around
Hi @ccg ,
You will be able to set up Ruuvi Gateway to relay data also to HTTP(S) / MQTT(S) server.
In order to do this you will need access to Ruuvi Gateway UI to configure it remotely.
