I have received my Gateway and connected three sensors to it. Now, I’d like to connect it to various automation. I can’t seem to find any documentation on how to query either the gateway or Station to retrieve sensor data. I don’t want to use custom MQTT, I want to send the data to Ruuvi Cloud and talk to an endpoint to get the data I need.
I have seen some other gists/examples in various places which reference a /history endpoint, but on my gateway, it does not work, and just returns the following json:
In addition, if I try to go to the gateway local address via http - all I have is the option to select Suomi or English followed by “Access denied” in both languages - there is not even an option to login:
I have the same issue. I’d love to reconfigure the station to send data to a custom HTTP server (as described in the advanced config guide), however I can’t work out how to log into the station and reconfigure it. All I get is the Access denied message.
To reconfigure the Gateway, you have to briefly press the configuration button and then configure via the Wi-Fi hotspot. Here you can find quick start guide:
We agree that the configuration flow is not yet perfect and several enhancements related to these problems and feature requests have been already implemented and a new firmware release will be published relatively soon.
